Hot Rods Beehive Oil Filter replacement cartridge
Discussion in 'The Hokey Ass Message Board' started by JIM D, Apr 21, 2011.
  1. JIM D
    JIM D
    I'm trying to find a replacement oil filter cartridge for my beehive oil filter other than ordering it from Speedway? Does anyone have any idea of cartridge that can be used in these.
    Thank You:confused:
  2. Bruce Lancaster
    Bruce Lancaster
    I think same as regular flathead. Someone on Fordbarn just posted a whole stack of numbers for that:
    Here's some numbers:
    NAPA #1006
    Purolator #P-24
    Motorcraft #FL25
    Wix #51006
    Fram #C4
    AC #P209
    Ford #7HA6731A
    Disregard if this is something like a Hildebrand full flow and not a byp***!
  3. Dirty Dug
    Dirty Dug
    I believe it's the same part number as a stock oil filter cartridge. Maybe try Napa.
  4. JIM D
    JIM D
    I went to Advanced Auto parts and ordered a stock filter and the measurements were different from the Beehive. The stock filter measured 4 1/4 inches by 4 3/4 inches. The original beehive filter measures 4 inches by 5 inches.:confused:
  5. I have a replacement element from Offenhauser on its way to me , when it arrives I'll add the part numbers off the box here if that helps .
  6. cuznbrucie
    cuznbrucie
    I used the NAPA #1006, as mentioned by Bruce Lancaster above......it is the *right* one for the traditional Fillcoolator style beehive......
    Trust me.....
    CB
  7. tig master
    tig master
    from up north
    lf 101 hastings
    4 7/32" od
    4 7/8" long
    Baldwin p41 dimension same as hastings
    puro L30034 4.21 OD X 4.870
    TIG.
  8. Bob K
    Bob K
    from Antigo Wi.
    I use a Wix 51006 in mine
    B:)B
  9. JIM D
    JIM D
    Thank You for all the help. I really do appreciate it.
  10. Please post what you find that works so that when someone does a search in the future they'll get the answer. I'd start with what Pops uses (a Wix 51006) and let us know.
