Been A While Since I Was A Newbie
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by 1959Ford, May 15, 2007.
  1. 1959Ford
    1959Ford
    Hi All. Thought it to be high time I got in gear and registered on the HAMB. Glad to be here. I have a 1959 Ford 4 door Ranch Wagon that I am in the process of restoring. Quick specs are: Ch***is Lowered 7" on air shocks, Body channeled 3", Converted to 4 wheel disc brakes, swapped in 472 Big Block Ford / C6, etc. Picture below.
    BTW: I do quite a bit of tech writing for OSR, and thought I would share with you all. Is the best way to post a tech article simply to start a new thread? Cheers.
  2. Flathead Youngin'
    Flathead Youngin'
    Good looking project and welcome to the best hot rod garage on the planet!
    Yes, just start a new thread in the appropriate section.......
    Good tech will make you a rock star on here:D
  3. 1959Ford
    1959Ford
    Thanks for the welcome. I just posted 14 separate tech articles, making for about 50 printed pages. I hope you enjoy it. I start all my tech posts with "How To:" if you care to browse the articles. Cheers.
  4. sawbuck
    sawbuck
    from 06492 ct
    welcome to the hamb.
  5. Mule Farmer
    Mule Farmer
    from Holland MI
    I see you been posting all kinds of how to threads, thanks and welcome
  6. 1959Ford
    1959Ford
    Well- I posted some of my tech hoping people would find it informative. Instead, I got flamed, accused of ripping it off, dismissed as incorrect, etc. I can do without that, so I think this is the last time I ever come back to the HAMB. Thanks to those who were welcoming; the others really do you all an injustice.
  7. zman
    zman
    from Garner, NC
    I didn't acuse you of ripping anything off, just being a little gung ho with the cut and paste. Sorry your ***** hurts so bad that you have to run away.
  8. Flathead Youngin'
    Flathead Youngin'
    I think you ran into ole' Zman.....he's a heck of a guy on here.
    However, if I had seen a new fella come on here and post that many techs and that they are so polished, I would have been su****ious of you just copying a mag article......but, I'm ***uming you wrote them....
    You'll be fine, just read for a while before you post to get the "hang of it".......seriously
  9. Hackerbilt
    Hackerbilt
    Zman didn't do anything wrong. YOU came on WAY too strong.
    Don't worry about it Z...this whole deal almost smells like a setup.
    I'm sure we'll be able to read about it all eventually anyway...
  10. Neophyte
    Neophyte
    Hey Dude!?! Why take it so personally? Life's to short for that.
    A lot of your "tech articles" are good stuff and very informative. BUT if you want to write these kind of things you must be prepared to take criticism on what other see as incorrect detail. You must be able to own up to possible mistakes or be prepared to defend why you wrote what you did. It doesn't help running away with your tail between your legs or to be overly sensitive of criticism because evrybody will then think you're an a$$.
