1952-59 Ford Been away for a while
Discussion in 'Off Topic Hot Rods & Customs' started by 56 tudor post, Jan 16, 2017.
  1. 56 tudor post
    56 tudor post
    20170116_090152.jpg 20170116_090328.jpg 20170116_090232.jpg 20170116_090407.jpg 20170116_090500.jpg I have been focusing my attention on other projects as of late. As of about two weeks ago I decided to get back into my garage to get the 56 customline on the road. I was initially thinking of going with a 5.0 EFI system on it. I even purchased a bob Drake fuel tank for EFI it is a very high quality piece, and I have a complete 5.0 EFI system. Instead I just opted to stay carbureted. I installed an AOD, and a Lokar column shift linkage kit, and a Lokar TV cable. As for the rear end I am using a Ford Explorer unit with disk brakes and 4.10:1 limited slip that has had the long side cut down to fit the short axle. I have 17X8 American racing torq thrust wheels with 255 45 17 Kumho Ecsta tires with 1/4" wheel spacers. on the front I have 17X7 torq thrusts with 205 40 tires. The front needs more tire I am thinking about going with 225 40's.
    This is the second time I have installed an AOD into a cl***ic car, and both times I had the same problem after initial installation the car would only go into first and reverse. The first time I installed an AOD it was in a '68 mustang and the rebuilder just sent me out a new one, and it was a fantastic transmission for many years. before I purchased this transmission I drove the car it was in and it drove great, but that was 2 years ago. What would cause the AOD to only shift to Reverse and First. like I said I have performed this swap before and The last swap I did drove for abut 6 years and 90,000 miles flawlessly. I used the pressure port and set the TV cable correctly.
    Here are some pics. Let me know what you think of the stance. I like it now, but when I get in the car it lowers about 2.5 inches. The springs front and rear are very soft. I have new shocks front and rear. I know I will need new springs. Any suggestions on where to get leafsprings would be appreciated.
    Thanks
    Chris 20170116_090152.jpg 20170116_090328.jpg 20170116_090232.jpg 20170116_090407.jpg 20170116_090500.jpg
    Rui likes this.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    If the AOD has sat for a while they have a habit of the governor sticking,take it out and give it a generous cleaning with Brake-Kleen more info here too : http://www.network54.com/Forum/260730
  3. JeffB2
    JeffB2
    from Phoenix,AZ
  4. 56 tudor post
    56 tudor post
    Sorry something went wacky with the pictures.
  5. 56 tudor post
    56 tudor post
    Thanks Jeff. I have checked out their website. Looks like good stuff.
  6. PapaVolume
    PapaVolume
    I like the stance, but like you said, the front tire definitely needs more sidewall.
  7. 56 tudor post
    56 tudor post
    Thanks papa. I have an appointment with the transmission shop tomorrow. If they can fix the transmission quickly I will take it to the body shop for new floors and paint. I still need to block it again. The body is very straight.
    I have a dilemma though. The front crossmember is badly corroded. I will need to replace it, or go with a mustang II front end. My wife's ex is a metal fabricator and he said he could fab me up one from drawings he has for around $800.00. His company make SCORE trucks suspension components. I would still have to come up with brakes and shocks and springs. Do you think that I should go with the mustang II or just replace the front crossmember and put on an aftermarket brake kit.
    Thanks
  8. the-stig
    the-stig
  9. JeffB2
    JeffB2
    from Phoenix,AZ
  10. 56longroof
    56longroof
    The stock suspension is actually pretty good. I don't think you would benefit from a mustang II that much. How bad is the crossmember? Can it be repaired or need complete replacement.
  11. Dos Cincos
    Dos Cincos
    Not sure if this is on purpose or not but your rear shackles are flipped down in several of the side profile pictures.
  12. Texas57
    Texas57
    I haven't looked at the Mustang II kits, but I wouldn't think they replaced the old crossmember anyway, only the a-arms, so the crossmember would still be needed.?.? Don't know, just thinking out loud here. Unless you're building a pro-street, these old suspensions are quite good. jmho.
  13. 56 tudor post
    56 tudor post
    As far as th crossmember goes. It is almost completely rusted through where the p***enger A-arm connects. An there are a few places where it is rusted through.
    As far as the rear shackles go. The previous owner had the car lowered with 4" blocks. He even modified the transmission tunnel so the rear end wouldn't hit the floor. And for some reason the leafsprings are only 2 leafs. The car can barely support it's self. I don't know if flipping the shackles helps lower the car or not but when I bought it the exhaust tips were flat from dragging on the ground.
  14. 56 tudor post
    56 tudor post
    I was leaning towards replacing the crossmember just for the simplicity. I want to get this car finished and enjoy it.
    Thank you
    56 tudor post
  15. 56longroof
    56longroof
    Flipping the shackles back to factory position will lower it about 2". Found that out from experience.
  16. 56 tudor post
    56 tudor post
    I got the transmission working. The governor was stuck and the valves in the valve body were very sticky. Now it shifts up through the gears fine, but when coming to a stop It almost stalls because the transmission isn't downshifting fast enough. almost like if you don't clutch a manual before you come to a stop. the car shudders and RPMS drop and then it shifts down and the TC releases (starts to slip)
    I also got my crossmember and floor boards I will be installing those within the next couple of weeks.
  17. JeffB2
    JeffB2
    from Phoenix,AZ
  18. DIYGUY
    DIYGUY
    from West, TX
    had a 700R4 like that. It was the converter staying locked up. That ****** had a solenoid that controlled the converter. Not familiar yet with the AOD but sounds like the same thing.I think the AOD has a mechanical locking converter, so is it the converter itself or another valve sticking that controls oil flow?
