Before welding, read this- seriously...
Discussion in 'The Hokey Ass Message Board' started by Scotch, Jul 29, 2009.
  1. Slim Pickens
    Slim Pickens
    Thanks 'Scotch' and 'The 37 Kid'. Slim
  2. olskoolspeed
    olskoolspeed
    from Ohio
    Thanks for posting this.
  3. VonMoldy
    VonMoldy
    from UTARRGH!
    Geez I was just out using some brake cleaner a few minutes ago and saw the warning on the can!
    I will never use this stuff before welding!
  4. sloorider
    sloorider
    Brother, you have to be even more cautious when soldiering/brazing copper lines and fittings that have been in service.
    Residual ref. is still a possibility, remember to nitrogen purge your lines etc...
    Also when getting your medical check up, inform the lab doing any blood work that you work with ref, I believe it is the pot***ium levels that must be monitored.
    Most likely anyone exposed to gases may indeed want to do same.
  5. ago
    ago
    from pgh. pa.
    Buy only (NON- CHLORINATED) brake clean.
    Ago
  6. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Printed it out and hung it in the lunch room at work Monday
  7. SakowskiMotors
    SakowskiMotors
    Wow
    I have cleaned w/ that brake cleaner and welded.
    Lucky.
    Thanks for the post. I am going out into the shop now to tell the guys.
    wil
    www.sakowskimotors.com
  8. b-bob
    b-bob
    Scary ****! Thanks for posting. This is how the word gets around that these chemicals are dangerous.
  9. JD's 32
    JD's 32
    from TX
    Damn! Thanks, now i'm scared of everthing i have to clean with.
  10. Me too............................
    Thanks for posting, sad story.
  11. Jalopy Joker
    Jalopy Joker
    If you are feeling that bad-CALL 911-he could have died-at least could have minimumized what happened. When you are really hurt or hurting that bad dial 911.
  12. 325w
    325w
    ???? How do you print just the part of the thread you want ????????
    Gray hair person.
  13. Beau
    Beau
    Gulp. Damn...
    That's scary. I don't use brake or carb cleaner when welding. But I do use anti-splatter spray when I run flux core.
    Are there other chemicals that will also cause this other than what's been posted?
  14. Diesel627
    Diesel627
    holy ****!!! Thanks for posting this!! I've meet brew dude at the smoke out, and spoken with him on the quad cam *******s board. He's a super nice stand up guy I hope he's gonna be ok!! That's some crazy **** I do some tig welding and alot of mig, I'm gonna remember this one, **** it sounds horrible and could happen to anyone
  15. sloorider
    sloorider
  16. sloorider
    sloorider
  17. john walker
    john walker
    when an engine ****s in brake cleaner fumes, what is the stinky gas that comes out the exhaust? probably not phosgene or i would be dead now.
  18. sloorider
    sloorider
    Not necessarly, let's work save but not get paranoid
  19. john walker
    john walker
    anyone else with a real answer?
  20. oilslinger53
    oilslinger53
    from covina CA
    Thanks for reposting this, I missed it too. These type of things should be reposted from time to time. It's not like he reposted about the new rebel rodz or how to install an air bag and four link set up... On a related note, NEVER ALLOW AMONIA AND BLEACH TO COME IN CONTACT WITH EACH OTHER!!! It results in mustard gas!!
  21. oilslinger53
    oilslinger53
    from covina CA
    Be careful to recover freon if you're working in a low, or enclosed area instead of just cutting the lines and letting it run out (not that we would do that :)..) Burning freon also results in poison phosgene gas.
  22. 327-365hp
    327-365hp
    from Mass
    Thanks for posting that, I had no idea that could happen.
  23. Mark H
    Mark H
    from Scotland
    Posting this here as well incase you havn't seen the other thread.
    P.T.F.E. Tape.Pretty inert stuff,right?You can swallow this stuff with no ill effect,But,when subjected to naked flame ,it gives off poisinous gas.If I remember correctly,it's CYANIDE.
    When serving in the R.A.F. in the '80s we recieved a safety bulletin regarding transmission seals on I think,Ford ******s.These seals,when burning,give off a toxic gas that can be FATAL ON FIRST CONTACT.
  24. musicrodder
    musicrodder
    from Upstate NY
    Thanks for a good tip. I'll have to remember this when working on all the welding projects.
  25. Got a an email from a chemical engineer who mentioned this about brake fluid...
    Car Brake fluid and chlorine tablet for pools: It will generate a nice flame and produce chlorine gas.
    Be careful if they get stored near each other in your garage... an old bottle of brake fluid gets a leak next to a chlorine tablet sitting loose on a shelf can go WHOOSH!
    Any of you pyros out there, DON'T TRY THIS AT HOME!!!
    Also (Coca or any kind of) Cola and those chlorine tablets produce deadly chlorine gas when they come in contact.
    Have a nice day!
  26. 39cent
    39cent
    from socal
    one of the first things welders learned in the Navy is about safety, so your son will know about that. I didnt know about it when I went in, and had been welding at home for years and was one of the first things we were taught. [phosgene gas is 'mustard gas' and was used during ww1 by the Germans].
    see this http://en.wikipedia.org/wiki/Haloalkane
  27. Scotch
    Scotch
    I hear ya Duane. I was in the AF from 84-88 and we used Trichloroethene (trike) to clean the bathrooms and stuff. It was just 'cleaner' to us then...
    But this is different stuff, especially when exposed to open flame and argon gas...
  28. skidsteer
    skidsteer
    Moderator, please consolidate these. thanks.
  29. gas pumper
    gas pumper
    If it makes the gas during welding heat, it could be the same product going thru the engine, but maybe not because of the closed combustion.
    I had an R-12 leak that was the high side hose that went thru the same body ducting as the engine air intake on a Detroit Diesel. The fumes were awful, But I'm still here. So maybe it isn't phosgene when going thru an engine.
    How about those snifer freon leak testers? Nice blue flame turns to green.
    How many of us have done that?
  30. Godspeed
    Godspeed
    Yikes! Thanks for posting!
    I guess reading the label is all we can do. I saw that checking for 'Non-Clorinated" was a good idea. Is there any "safe" cleaner for welding?
