Projects Beginner Car Purchase
Discussion in 'The Hokey Ass Message Board' started by TimTheEnchanter, Dec 16, 2020.
  1. TimTheEnchanter
    TimTheEnchanter
    from Texas
    Hi everyone!
    I’ve posted here before but looking to get my first car, a 1930s coupe. The frame and body are very solid, everything original is there and it’s pretty good to go. The only thing that’s questionable is the engine since the battery was dead when we tried to start, no voltage on it nothing happened.
    The asking was 7500, I’ve researched around and it seems that running 30s coupe go for anywhere from 8k to high teens/low twenty’s for stock.
    My question for a questionable engine/battery/electrical(?) is the price still fair? Everything seems solid and at 6’6’’ It was a perfect fit which is hard to do for me. I’m pretty mechanical adept. Is this kind of expected with Cars this old?
  2. 302GMC
    302GMC
    from Idaho
    Well, Tim,
    What kinda car is it ???
    loudbang and lothiandon1940 like this.
  3. 56don
    56don
    Will the engine turn over by hand (wrench)? If so, take a battery with you and check it out.
    Ya know, if you don't post pictures then we think you are making it all up...;)
  4. DDDenny
    Here is what I think about buying an engine (any engine) whether with body or not.
    Believe half what the seller tells you, then make an offer!
  5. 283john
    283john
    The original engine?
  6. 31Apickup
    31Apickup
    What make of car, any photos, keep in mind many early cars are positive ground.
    ClarkH, loudbang, 56don and 1 other person like this.
  7. lothiandon1940
    lothiandon1940
    Man, you got to give us more than that to go on. There are about a hundred different '30's car makes.
    jim snow and loudbang like this.
  8. J. A. Miller
    J. A. Miller
    from Central NY
    Find the hand crank in the trunk and give it a spin.
  9. wvenfield
    wvenfield
    Big difference IMO from a 31 or 32 or a 36.
    As already noted........no way a person can answer. I would ***ume a 30 or 31 Ford based upon your numbers but we can only guess.
    If a 31 and it's the stock 4, are you even going to keep it that way?
  10. 19Fordy
    19Fordy
    Without photos and vehicle info. you will never get a meaningful answer.
  11. Kiwi 4d
    Kiwi 4d
    Engines and batteries are consumable commodities ,if everything else is solid jump on the deal . But we really need to know what the car looks like.
  12. TimTheEnchanter
    TimTheEnchanter
    from Texas
  13. TimTheEnchanter
    TimTheEnchanter
    from Texas
  14. TimTheEnchanter
    TimTheEnchanter
    from Texas
    1930 chevy
    Lil32 and loudbang like this.
  15. TimTheEnchanter
    TimTheEnchanter
    from Texas
    1930 Chevy I posted pics at end
  16. TimTheEnchanter
    TimTheEnchanter
    from Texas
    Stock i6, and yeah kind till something goes then maybe a more modern engine. I really like it for what it is
  17. TimTheEnchanter
    TimTheEnchanter
    from Texas
    Original engine yes, i6
  18. flatford39
    flatford39
    OK it's a 30 Chevrolet. Make sure you check out all the wood subframes. These cars are loaded with wood unlike a 30 Ford coupe. It's a nice looking car but I put it in the $4,500.00 range. Does it have a clear ***le in the owners name???
    irishsteve, ClarkH, rockable and 3 others like this.
  19. J. A. Miller
    J. A. Miller
    from Central NY
    There's a LOT of wood in those Chevy bodies. In most cases it needs to be replaced with either a new wood kit or some guys replace it with steel. Either way, it's a big job.
  20. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    1930 chevy.... Are you a good carpenter? There is a TON of wood holding that body together. Moreso than a Ford of the era. Ever wonder why you dont see old Chevys like you do Fords??? thats why.
    Cut the price of a Ford in half, and thats about a Chevy of the era price. It does appear to have Ford wheels on it. Id be more like 3K on that car if I were looking and REALLY liked it
  21. TimTheEnchanter
    TimTheEnchanter
    from Texas
    It is
  22. TimTheEnchanter
    TimTheEnchanter
    from Texas
    Lol probably not as good as that. Yeah and that’s what I need to hear. I looked at the wood in the roof, check the bottom of the doors and everything seemed solid.
    I think they might sell wood kits though? And I guess the option of steel tubing?
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    If you have not bought it already don't buy it. An early chevy is a bad car for a beginner to cut their teeth on. do yourself a favor and get a Ford (this coming from a dyed in the wool chevy guy) Just imagine the doors alone, they are made out of wood with a sheet metal skin bent over it and held on with nails. The wood gets rotten and the nails get loose and it is a mess, and that is just the doors
  24. WiredSpider
    WiredSpider
    If the wood is bad,then it is twice as much work to end up with a car worth 1/2 of what a similar Ford is.
  25. adam401
    adam401
    Yeah buy a Ford. The aftermarket support is unparalleled. Used parts are much easier to find. I think that Chevy is worth about 4500 to 5500 as it sits
    Buy yourself a running model A roadster for 12 grand, rip the fenders off and never look back.
    greener200 and triumph 1 like this.
  26. TimTheEnchanter
    TimTheEnchanter
    from Texas
    I have definitely not bought it yet. I felt like the wood is a little outside my wheelhouse with as much as there is. That’s why I wanted to double check with the H.A.M.B. since there is not a ton of info about these in comparison with model a’s. The search continues I guess. Bummer cause the size was perfect. I got in it way better than the a
  27. TimTheEnchanter
    TimTheEnchanter
    from Texas
    So I think the just of this thread is
    1. $3000-$5000
    2. There’s a reason we no longer use wood
    3. For a beginner, model a err’day
    Thanks H.A.M.B., this is why your guys website is a great resource and I really appreciate the feedback this got. I had that uneasy feeling from the “Termites and Bow ties” thread and just needed some input from people much more experienced than myself.
    clem, kidcampbell71 and 302GMC like this.
  28. 19Fordy
    19Fordy
    Do yourself a favor and let someone else have the opportunity to restore that car.
    It will drain your wallet. In today's market you can find an old Ford.
  29. hemihotrod66
    hemihotrod66
    Always make sure you have a good ***le....
    lonejacklarry likes this.
  30. 38Chevy454
    38Chevy454
    If you like GM cars, for the most part they went to all metal in 37 and up. Agree that coupe is way beyond a first timer project. Ford Model A can be found in good shape for the money you were looking. Even a stock banger powered Model A is a reasonable driver.
    TimTheEnchanter and 302GMC like this.
