Beginning of mandatory water based paints?
Discussion in 'The Hokey Ass Message Board' started by havi, Jun 17, 2009.
  1. skullhat
    skullhat
    buffings the same, as you use the same clear you were using before.
    you spray with 80% overlap, so yes it goes on pretty wet. runs are not as common as with solvent based, but you still want to avoid them.
    skull
  2. skullhat
    skullhat
    the more humidity , the slower its gonna dry. as somebody posted, the air flow is the most important for cure, but a little heat will also help dry it out.
    on real humid days i run up the infra reds, and the turbine guns and it will usually dry in 6 minutes or so.
    having all the air blowers in the booth is a nice feature but its expensive, and you need a hi-output compressoor to keep up with them.
    in production shops it will be neccesary. smaller guys can get by with a couple turbine blow guns.
    skull
  3. jakesbackyard
    jakesbackyard
    from ND
