Technical Bell housing for Tremec/EAB Flatty
Discussion in 'The Hokey Ass Message Board' started by knucklenutz, Mar 27, 2014.
  1. knucklenutz
    knucklenutz
    I'm building an '29 Tudor AV8. I'm using thru the floor pedals with hydraulic clutch actuation. The car came to me with a T-5 S10 trans. After inspection, I decided that I wanted the beef offered by the SN95 Tremec. The problem that I have is that the Tremec is built around a Ford case. Quicktime offers a bell housing for SN95/ '49-'53 Flathead. However it is set up for the GM style clutch. I really want to retain the Flathead clutch release. At present, modifying a Speedway S10/ Flathead bellhousing is all I have to solve the problem ( lots of welding an milling to modify it for the Ford /Tremec case.)
    Any suggestions ?
  2. 36tbird
    36tbird
    Go to Flathead Jack's website. There are lots of pics of bell housing adapters for all sorts of trans to f/h's there.
