Projects Belly Tank Build, NZ.
Discussion in 'The Hokey Ass Message Board' started by 26 T Ford RPU, May 3, 2021.
  1. saltflats
    saltflats
    from Missouri
    Looking good.
    Stogy, AndersF and 26 T Ford RPU like this.
  2. 26 T Ford RPU
    26 T Ford RPU
    Thanks:cool::D JW
    Stogy likes this.
  3. 26 T Ford RPU
    26 T Ford RPU
    Kept busy and put more mounts on and made two more templates. JW
    Stogy, brEad and saltflats like this.
  4. 26 T Ford RPU
    26 T Ford RPU
    Started designing the front body section's hinge and mount. JW
    Stogy, brEad, saltflats and 2 others like this.
  5. 26 T Ford RPU
    26 T Ford RPU
    Mucking around with arm ratios, back arms need to be longer. I hope to use gas struts to hold the front body up, it only needs to go up enough for me to get in/ out without a fight. JW
    JamieUC, Stogy, brEad and 6 others like this.
  6. Wgtn Dave
    Wgtn Dave
    Just binge viewed the entire 26 pages. Wish I'd found it back at the start. Nice bit of work. Cars and Coffee trip to Southwards next summer?
    Stogy and 26 T Ford RPU like this.
  7. 26 T Ford RPU
    26 T Ford RPU
    Thanks and won't be making Southwards as it's too hard to get to from home, will have it in Levin in October and the Featherston show in November. JW
    Stogy, Nominal, Kiwi 4d and 1 other person like this.
  8. Kiwi 4d
    Kiwi 4d
    Dang ,we will be at Trog in October, so will miss seeing it at our show in Levin.
  9. 26 T Ford RPU
    26 T Ford RPU
    TROG sounds better. maybe when you do see it i will have it running.... '' maybe'' :D JW
    Stogy, brEad, loudbang and 1 other person like this.
  10. 26 T Ford RPU
    26 T Ford RPU
    Small bit of progress, made the panels and fitted them. Just need to work out the two side bits that go under the seat, the back bits have a bulk head to stop things rolling away and back into the hard to get out area. JW
  11. 26 T Ford RPU
    26 T Ford RPU
    Got the six floor panels wrapped up today. as i was welding in some side supports i had a thought.... will the seat still squeeze out, short story NO! Removed them (not really needed) and presto it worked, getting the seat in/out is like a Chinese puzzle.
    I have some bits arriving tomorrow, fuel pressure reg, fuel filter and rollover valve so i can finish that system off. More on that soon. Moving forward.:) JW
  12. Stogy
    Stogy
    Awesome progress JW...;)
    26 T Ford RPU likes this.
  13. 26 T Ford RPU
    26 T Ford RPU
    Thanks, Steve.:) JW
    Stogy likes this.
  14. 26 T Ford RPU
    26 T Ford RPU
    Finally got the final fuel system parts, spent an hour or so moving them around, getting different fittings and bending some tube. This is how it will be for now and need to fit a mount to the tank to hold the regulator and filter. I know the regulator should be closer to the carb but will try this and see. Need to drop the lower body to remove the tank to weld the mounts on the front of it and make the final tube from filter to the fuel tank outlet. Still need to finish the fuel shut off valve also. JW
    Stogy, rjgideon, brEad and 6 others like this.
  15. 26 T Ford RPU
    26 T Ford RPU
    Was going to make some cribs for the front wheels to allow the lower body to slide out but made these stands instead. They break down for transport or storage. JW
    Stogy, das858, saltflats and 2 others like this.
  16. 26 T Ford RPU
    26 T Ford RPU
    Been very cold at night so don't get out in the shop much after work but been doing small bits in the weekends like mounting points for leg protectors and other safety stuff. Will do all needed so i can strip it down in the next month or so and paint the frame and put all finished items back on. JW
    Stogy, brEad, saltflats and 4 others like this.
  17. 26 T Ford RPU
    26 T Ford RPU
    Took the fuel tank to work and had Todd do his magic with some ally TIG welding on some mounting blocks on the tank, these will hold the fuel pressure regulator, two on the top for the breather tube that will have the roll over valve the the end and another for a bracket to hold a return spring for the fuel shutoff valve. JW
    Stogy, brEad, loudbang and 2 others like this.
  18. 26 T Ford RPU
    26 T Ford RPU
    Also cut out the first safety panels for my legs. These will need some fine tuning and most likely some thin padding and i will get in and see how i fit with them, its a start. More soon. JW
    Stogy, brEad, loudbang and 5 others like this.
  19. saltflats
    saltflats
    from Missouri
  20. 26 T Ford RPU
    26 T Ford RPU
    Thanks, it's appreciated.:cool::) JW
    Stogy and saltflats like this.
  21. spanners
    spanners
    Carry on and get it done. Can't wait for the first run video.
  22. 26 T Ford RPU
    26 T Ford RPU
    That make two of us......more like a lot more.:rolleyes::) JW
    Stogy and Dick Stevens like this.
  23. 26 T Ford RPU
    26 T Ford RPU
    Welded some more mounting tags on and made some more safety panel templates that i will make this week. JW
    JamieUC, Stogy, juan motime and 4 others like this.
  24. 26 T Ford RPU
    26 T Ford RPU
    Due to the R/H leg guard fitting where it needed to be i ran into some clearance issues with the brake lever which when resolved created clearance issues with the safety fuel valve lever thing, the fix will be to remove the mount for it an refit it closer to the outside in the frame. This is where i got it to fit best but was still in the way. JW
  25. Dave G in Gansevoort
    from Upstate NY
    Measure once, curse twice...
  26. 26 T Ford RPU
    26 T Ford RPU
    Dave, it worked fine before but needed to tweak the brake handle a little for the leg guard and moved the issue. I have almost done making the new bracket. JW
    Stogy, brEad, AndersF and 1 other person like this.
  27. 26 T Ford RPU
    26 T Ford RPU
    Made and try fitted the other two safety panels... all good there and also re mounted the fuel shut off lever and will work fine now. Next up will be some seat supports to stop the seat back collapsing rearward in an OH **** moment. More soon. JW
    Stogy, saltflats, brEad and 3 others like this.
  28. kustomkat1950
    kustomkat1950
    from Coastal GA
    Love it!! Have wanted to build one for a hot minute...OT Q, is that a Boerboel on pg 24? If so, this man has impeccable taste!!
  29. 26 T Ford RPU
    26 T Ford RPU
    Thanks but not sure of your question of P 24. JW
    Stogy likes this.
  30. KiwiGlen
    KiwiGlen
    I think kustomkat1950 is asking about the dog breed in this photo...
    Glen.
