Projects Belly Tank Build, NZ.
Discussion in 'The Hokey Ass Message Board' started by 26 T Ford RPU, May 3, 2021.
  1. 26 T Ford RPU
    26 T Ford RPU
    Thanks, Pete and yes i have been into Willy from 75...someone had to be.:rolleyes:
    The 37 Willys could whip any V-8 in a gymkhana but not the Model A's.
    Will see if this can beat some V-8's too.:D JW
    VANDENPLAS, kiwijeff, Stogy and 2 others like this.
  2. 26 T Ford RPU
    26 T Ford RPU
    Setting up for the axle mounts. JW
  3. 26 T Ford RPU
    26 T Ford RPU
    Made a simple jig to hold the mounts in phase for tacking, worked a treat. JW
    Jet96, kiwijeff, kadillackid and 4 others like this.
  4. 26 T Ford RPU
    26 T Ford RPU
    Plasma cut the mount plate at work. JW
  5. 26 T Ford RPU
    26 T Ford RPU
    Lining it up and triple checking. The fuel tank will go behind the axle. JW
  6. 26 T Ford RPU
    26 T Ford RPU
    Height adjusting mount holes drilled and a couple of bolts to check it's all good. JW
  7. 26 T Ford RPU
    26 T Ford RPU
    And the other side. Will make templates for some gussets next week. JW
  8. JamieUC
    JamieUC
    from Swansea UK
    Looks good JW, sounds like you have some good events to go racing at, have you got a target year for going to Bonneville? I'd love to ship my car out to the state's and race at Bonneville but I think my wife has other plans for what to do with my income [emoji1] but you never know.
    brEad, Stogy, AndersF and 2 others like this.
  9. 26 T Ford RPU
    26 T Ford RPU
    IF i can get there it would most likely to be 2024 as i retire in December 2023 but in the mean time i am pulling out out all stops (within reason) to get it racing here sooner. My wife wants to drive the Tank as well and also drive our RPU as push car.
    Your build is giving me good inspiration. :cool::cool: JW
    kiwijeff, brEad, Stogy and 3 others like this.
  10. 26 T Ford RPU
    26 T Ford RPU
    Axle mount plate tacked in and gussets on the axle. JW
    kiwijeff, brEad, AndersF and 3 others like this.
  11. 26 T Ford RPU
    26 T Ford RPU
    I also got the lower ch***is rear pieces in place. JW
    AndersF, loudbang and Stogy like this.
  12. 26 T Ford RPU
    26 T Ford RPU
    Next will be to flip the ch***is and put the lower body over it and start making the lower hoops and rear axle reliefs. hope to get the front hubs back soon so i can mount the front axle and make it a roller. JW
    VANDENPLAS, The 39 guy, brEad and 5 others like this.
  13. Stogy
    Stogy
    Looking good JW...will you be canopied in (closed cabin) or in the wind?
  14. 26 T Ford RPU
    26 T Ford RPU
    Thanks, Stogy. closed in is what i am working on, just need to see how low i can get head and roll cage... its looking promising, i just need to work the framing under the seat without safety and structural compromise. JW
  15. loudbang
    You are moving right along on it now. :)
  16. 26 T Ford RPU
    26 T Ford RPU
    Yip.... on a mission, been dreaming about building this for way too long and with Land Speed events here and only hours away i NEED to get it done. JW
  17. 26 T Ford RPU
    26 T Ford RPU
    Small amount of progress this week, ch***is bracing tacked in. The ch***is is upside down at present. JW
  18. 26 T Ford RPU
    26 T Ford RPU
    Also made the templates for the ch***is hoops. JW
  19. 26 T Ford RPU
    26 T Ford RPU
    A Belly Tank ain't real till its got its push bar. :cool: JW
    VANDENPLAS, kiwijeff, Stogy and 4 others like this.
  20. 26 T Ford RPU
    26 T Ford RPU
    With the bottom half sitting over the frame.the push bar will come out through the bottom section of the body, this will be cut when the body is bolted to the ch***is as i only want to cut the relief once.:rolleyes: JW
    VANDENPLAS, Stogy, brEad and 4 others like this.
  21. AndersF
    AndersF
    progress well.
    I will never complain again that its narrow in a T.
  22. 26 T Ford RPU
    26 T Ford RPU
    Thanks , Anders...i'm only 5'8'' so the T's not that bad but this is very different. Before i mount the seat and sort the drivers compartment i will need to get my full race suit to make sure i will still fit as i don't want any ''take two's or plan B's'':rolleyes::) JW
    kiwijeff, Stogy, panhead_pete and 3 others like this.
  23. 26 T Ford RPU
    26 T Ford RPU
    Working on the rear of the ch***is and made some gussets to support the frame over the axle. JW
    VANDENPLAS, Stogy, The 39 guy and 3 others like this.
  24. 26 T Ford RPU
    26 T Ford RPU
    I started the lateral ch***is hoops, and things didn't go to plan, i had the use of a pipe roller at a place i used to work at but it was slow going as it kept cutting out so i decided to try using my cheap pipe bender and do many small kinks. Well all was going well until the pump **** its self, after four hours i got four of the six done. JW
  25. 26 T Ford RPU
    26 T Ford RPU
    The offending piece of impeccable Chinese quality, i still have four days left on the one year warranty.:cool: JW
    VANDENPLAS, Jet96, Stogy and 5 others like this.
  26. 26 T Ford RPU
    26 T Ford RPU
    The four hoops ready for t*******, will fit them this week. The piece of pipe in front is the effort with the pipe roller. JW[​IMG]
    VANDENPLAS, Stogy, The 39 guy and 2 others like this.
  27. edcodesign
    edcodesign
    Nice work, love the engineering and design. I built one a wee bit smaller !
    Good luck,
    Ed.
    Jet96, LSJUNIPER, kadillackid and 2 others like this.
  28. 26 T Ford RPU
    26 T Ford RPU
    That's very cool and thanks.:cool::) JW
  29. The37Kid
    The37Kid
    Lots of progress since the last time I stopped by, looks great. Bob
    kiwijeff, 26 T Ford RPU and loudbang like this.
  30. 26 T Ford RPU
    26 T Ford RPU
    Thanks, Bob. Progress is slower than i would like, i feel a bit impatient with it but with designing as i go i have to be methodical. :rolleyes::) JW
