Belly tanker
Discussion in 'The Hokey Ass Message Board' started by millerkustoms, Feb 27, 2004.
  1. millerkustoms
    millerkustoms
    Here are a couple more pictures, they are about 8 months old. We are about to get started working on it again, we have a flathead for it now, and we going to a clutch drive with no ******... We wanted it to be "drivable" in the first place. but now we realize room won't allow. The tanks we are working with are smaller ones, we are not sure what plane they came from but as you can see they are not the desirable aluminum tanks. We are looking for a quickchange now, and we are rebuilding the frame out of rectangular tubing instead a discarded model A frame. I will try and put up picks of the v8 mock up tomorrow.
  2. millerkustoms
    millerkustoms
  3. SwitchBlade327
    SwitchBlade327
    lighter. don't think I've seen anyone else building one of these....
  4. SwitchBlade327
    SwitchBlade327
    other one...
  5. Cool!
    Where does the human fit?
  6. Unkl Ian
    Unkl Ian
    Direct drive is going to hurt acceleration.How far/fast are you allowed to push them?
  7. millerkustoms
    millerkustoms
    yeah, that was the problem with the ******, there was little room for the driver, but it looked as though it would work, with hand clutch, and gas a brake pedals... will turn out better with the v8 hopefully
  8. Farmer
    Farmer
    Looks like the Tom Beatty belly tank......frickin cool! Can I come over and see it? I live in Concord, I'll even bring you some beer.
    John
  9. Unkl Ian
    Unkl Ian
    While it wouldn't be exactly Vintage,you could probably fit a VW transaxle in there,the transmission would be behind the axle centerline.And the stock VW case can be modified to accept Hewland transaxle parts,so you can change all the gear ratios.The case can be run right side up,or up side down to get the crankshaft height where you want.
  10. millerkustoms
    millerkustoms
    Yeah FarmerJohn, just PM me, we can figure something out... and the VW transaxle is a good idea, but we are trying to stay pretty true, but keep it safe.
    -Jeremy
  11. cheaterstef
    cheaterstef
    Hi !
    Just wanted to let you know that I just bought an aluminum belly tank and that I am going to build a lakester as well.
    cheaterstef from thecheatersgang.com
  12. Why don't you try an in and out box like they use in a sprint car. You should even be able to find a 2 speed. That aren't very big and it would be a definate advantage, on or off the salt.
  13. I,m gonna start on mine soon(I hope) That thing is gonna be cool. I am up in the air on what motor to run, but I know I'm gonna go traditional instead of current for racing.
  14. cheaterstef
    cheaterstef
    ...cool !
    What aircraft does it come from ?
