Bellytank build - Power by the Fabulous Flathead Ford V8
Discussion in 'The Hokey Ass Message Board' started by awelker, Dec 5, 2008.
  1. Candy-Man
    Candy-Man
    Looks awsome... Great build.... Thx for posting the pic's of your frame build..... Nice work...
  2. retroridesbyrich
    retroridesbyrich
    from Central NC
  3. super sweet build keep up the good work . more pics please!
  4. awelker
    awelker
    The plan as of now is to be ready for Bonneville in 2010, it's a long trip and I want to be ready.
    Wasn't sure about trying it out at Maxton, how smooth is the co**** for a car with no rear suspension?
    For my steering box, I couldn't find anything that suited as-is so I designed a new housing and steering arm around early vw beetle inernals. So I have brand new internals with the ratio I wanted in a housing that was built into the front spring mount.
    swdobbs - Do you plan on going racing? Is that an original tank? Looks good!
    Zach - no fairing yet still in planning
    For the cad design it is all from scratch, the results of quite of few hours behind the computer and measuring alot of old rusty parts. Started with measuring the tank to draw the profile and then just kept moving things around until the look suited and everything fit. Worked great for designing the cage, very little waste while bending tubes. Both my brother and I are mechanical engineers that design expensive machines all day long, designing an drawing this stuff is a pleasure.
  5. Bobby Green
    Bobby Green
    Looking good. I see your following the Old Crow blueprints. It totally takes me back to my build a few years ago. Even our garages look similar. LOL
    Keep up the good work, We need more tanks on the salt.
  6. HemiRambler
    HemiRambler
    Wow! How sweet is that !!!!!
  7. Devin
    Devin
    from Napa, CA
    pardon my ignorance, is it common plazce to have a solid mounted rear end in a belly tank?
  8. Skotz
    Skotz
    WOW:D......11 posts and you come up with THIS.....WOW:D
    OK, I'm back down to earth now....Keep the updates coming, what an inspiration type post....
    Thanks for sharing your build.
    Skot
  9. Ol Deuce
    Ol Deuce
    from Mt. U.S.A.
    Your going Racing!!! Your Tank looks Great!!! Keep up the great work ,and keep us posted.
    Randy
  10. Very cool build!
    I like your solutions... steering box, neat idea!
    Thanks for sharing!
    Sam
  11. Straightpipes
    Straightpipes
    BTTT for the nightshift.
    I wonder if my pushcar will be done in time???:D
  12. Jalopy Joker
    Jalopy Joker
    Terrific project!! Have a buddy in Calif that is building one much like yours. Flat V-60, in out box to eliminate trans, quickchange, etc. Keep updates coming.
  13. doctorZ
    doctorZ
    are you talking about joe or do we both have friends building identical tankers!?
    -drZ
  14. Sixcarb
    Sixcarb
    from North NJ
    Great job looks like it is coming along very nicely.
  15. Unkl Ian
    Unkl Ian
    Solid mounted rear ends are not unusual on shorter tanks.
    Not enough length for a driveshaft.
  16. awelker
    awelker
    Here are couple of new pics. Slow progress but gathered some more pieces of the Hilborn, working on getting the main water tank fit in place. The water tank started as a aluminum 33 lb. propane tank. It still needs some mounting brackets made up but all signs say it will fit inside the shell.
  17. lonestarluck
    lonestarluck
    wow thats a cool build
  18. Eyeball
    Eyeball
    The tank is looking good. What is the capacity of that water tank? I have been told you should have around 25 gal to cool a flat motor for a run. I would like to hear other opinions on this.
  19. Grandadeo
    Grandadeo
    Good looking build. A lot of us will be riding along with you on this one. My tank went down the road. Squigy has it now. To many projects and not enough years left. Reality ****s.
    Lee
  20. Candy-Man
    Candy-Man
    You say "slow progress", however; very nice and keep the pic's coming.....
  21. Beef Stew
    Beef Stew
    from So Cal
    is the front hoop of your cage continuous?
    as for the coolant tank capacity our roadster had 10 gallon tank and it kept a number of hemis on big loads of nitro (90% or more) cool at bonneville with no problems. 25 gallons sounds a bit overkill for a low output flatty but having more cooling than necessary isn't a bad thing. plus it makes for good ballast.
  22. Liberty Garage
    Liberty Garage
    Great build. Looks like you are on the right track. I finished my tank for speedweek 2008. It takes a lot of planning to get 10 pounds in a 5 pound box. It appears we have used the same type of tank. I also did a CAD design and it helped immensely with the planning and build.
    good luck and go fast, libertygarage
  23. awelker
    awelker
    The tank itself will hold about 9 1/2 to 10 gallons, hopefully this will be enough. I may have enough room for two saddle tanks on each side of the oil pan but I may need this space for other things.
    My front cage hoop is one half hoop above the frame and one half below the frame, not one continuous hoop.
    Libertygarage, I saw your tank at Bonneville, it looked great. What was the top speed you ran? Did you stretch your tank?
  24. Ryan
    Ryan
    ADMINISTRATOR
    wow... great thread... gonna be fun to follow.
  25. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
  26. Beef Stew
    Beef Stew
    from So Cal
    Should be more than enough for a 3 mile run.
    I meant continuous above the main frame rail. It was hard to tell whether or not your front hoop was one piece or multi-piece in your pics. I'm a SCTA tech inspector so I these types of things pop into my mind.
    Good looking build.
  27. Very nice! In the next few years this is one thing I 'must' do.
    Care to share your CAD files?
  28. flatheadpete
    flatheadpete
    from Burton, MI
    Wow....gives me some new ideas. Thanks and keep us updated...PLEAS for the love of all that is hot rod, keep us updated.
  29. Casey
    Casey
    cool project, I want one.
  30. HD74
    HD74
    What a great project. What are the paticulars of the flathead?
