Technical Bench testing carbs
Discussion in 'The Hokey Ass Message Board' started by sdluck, Nov 1, 2022.
  1. sdluck
    sdluck
    What do you guys use to bench test carbs?
  2. 57 Fargo
    57 Fargo
    I typically use an engine.:D
    SS327, Moedog07, Bob Lowry and 3 others like this.
  3. sdluck
    sdluck
    Engine is not together at this time.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Well, other that hooking an electric fuel pump up to it to make sure that the needle and seat doesn't leak, I don't know what else you'd do.
    Moriarity likes this.
  5. sunbeam
    sunbeam
    You can blow through the fuel inlet and see if air goes through and then turn the carb upside down and see if it stops to check the needle and seat. then put some fuel in the float bowels though the bowl vents and check the accelerator pump and use a blow gun through the ventures and see if fuel shows up at the boosters.
    dogwalkin likes this.
  6. sdluck
    sdluck
    Thought of I heard where guys were using mineral oil to test the carbs without gas in them.
  7. Mike VV
    Mike VV
    from SoCal
    Other than Stromberg 97's, never was concerned with a needle and seat leaking !!
    Put the seat in clean and tight. Put the needle in, very clean. Set the float height per the book OR your desires.
    What else is there ?
    Mike
  8. You can use the old mineral spirits to check the squirting and pump......make sure is the old oily stuff (can't get it down here in Orange County). I wouldn't get it near the float unless it's br*** also.
  9. mohr hp
    mohr hp
    from Georgia
    C&S carburetors has a test rig set up that is essentially a flow bench. They can verify CFM at various throttle positions, find vacuum leaks. Pretty serious.
    Tow Truck Tom likes this.
  10. sdluck
    sdluck
    I had it flow tested they claim the needles and seat were bad,they are brand new. 3160 holley.
  11. sdluck
    sdluck
    It was a e bay purchase,party never used it.
