Bend a Roll Bar in Houston?
Discussion in 'The Hokey Ass Message Board' started by Ardun 32, Jan 19, 2010.
  1. Ardun 32
    Ardun 32
    Who can bend a 1 3/4" dia. x .120" wl. roll bar in a 180 deg bend with a tight (maybe 5") inside bend radius? Located in Houston.
    Thanks for any ideas. Don
  2. gimpyshotrods
    gimpyshotrods
    If this is for sanctioned racing, check the rules with the sanctioning body to see if there are bend radius specifications.
    It would **** pretty hard to find this out the hard way.
  3. Bearing Burner
    Bearing Burner
    from W. MA
    Most shoes for bending tubing of this dia. are larger than this aprox 7"
  4. Andy
    Andy
    Can you get a helmet in a 10" opening? Some padding would be nice too.
  5. manicmechanic
    manicmechanic
    Try Boccard 713-643-0681.
  6. 37FABRICATION
    37FABRICATION
    5" is very tight... and mine only runs 90deg.
  7. OHR281
    OHR281
    Call Bruces Rod Shop
  8. metlmunchr
    metlmunchr
    I sorta make my living manufacturing tube benders and dies. The bend radius is usually specified on the tube centerline. Common CLR's for 1 3/4 tube are 5.5", 6", and 6.5". 7" radius dies are available but not too common because of their cost. A 6" CLR die would give you a 5 1/8 theoretical inside radius on 1 3/4 tube, but the springback will likely give you a radius closer to 5 1/4". Any of the above radii will make a nice smooth bend on your tubing, so its a matter of finding a shop that has a die set that'll give you what you need. If you need to maintain some specific amount of space between the tubes, two successive 90* bends can be made with a short straight area between them to give the desired spacing.
  9. CaddyRat
    CaddyRat
    Brilliant link EWMN..thanks.
  10. InDaShop
    InDaShop
    from Houston
    My bender's radius for 1.75" is 6.25", but I cant bend 180's, I wouldnt be able to get the "U" off the shoe.
  11. CoolHand
    CoolHand
    Alliance Vendor
    I can bend 1 3/4" at 180 degs, but my dies have an 8" CL radius.
    Let me know if I can help.
  12. treb11
    treb11
    check the industrial fabricators that serve the petrochem industry here. Houston Blowpipe comes to mind.
  13. Aman
    Aman
    from Texas
    If you can't find it in Houston, forget it. Houston probably has more welding and fabrication shops than anyone in the US! Good luck and keep us posted OK?
  14. Ardun 32
    Ardun 32
    Hi and thanks to all who answered with some ideas. I have been out of town and just back. So far no luck but I'm still looking. I will advise if/when I find someone (anywhere) who has a tight 1 3/4" dia. die.
    Regards, Don
