Bending a 1953 GMC pitman arm
Discussion in 'The Antiquated' started by casper50, May 4, 2021.
  1. casper50
    casper50
    from alaska
    I've got the 350 installed in the 53 GMC and the steering column and box moved over. I can't find a photo of how the pitman arm is bent to line the drag link back up with the box. Can anyone post a photo of their bent pitman arm so that I have something to go off of? From my observation I'd say bend it outwards at the first bend from the hub and then bend the very end towards the rear of the truck until it lines up straight and with the hole. IMG_20210504_060752.jpg IMG_20210504_060804.jpg Thanks.
  2. 302GMC
    302GMC
    from Idaho
    Use a '55 - '59 1/2T pitman arm. Looks like you already have the right drag link.
    54EARL likes this.
  3. casper50
    casper50
    from alaska
    both are stock 53 GMC
  4. falcon2
    falcon2
    from michigan
  5. Okie Pete
    Okie Pete
    Call Sid at Nostalgia Sid’s Axles in Guthrie Ok or check out His web site . Lots of good information on there
