Bendix brakes on a 38 Chev spindle
Discussion in 'The Hokey Ass Message Board' started by vtwhead, Apr 22, 2009.
  1. vtwhead
    vtwhead
    OK, I am showing my age here. It seems that I remember years ago that we would bolt the 53-54 Chev backing plates and drums onto the 37 -39 Chev spindles to get five lug 15 inch wheels. Seems the top bolts on the spindle bolted up but we had to add a spacer to the bottom ones. Little fuzzy here as that was a long time ago. Anyway, I am faced with this proposition with a 38 Chev coupe that I am working on at the present time. Can someone tell me if this is correct and if not what I need to be looking for?
  2. maniac
    maniac
    There was a spacer on the bottom 2 bolts only if I remember right.
  3. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    I used 56 pickup spindles and backing plates and 54 p***enger car drums. Had to make special bushings cause the pickup spindles used a bigger king pin.
  4. 1951-54 Chevy would work, '51 the first year for the Bendix brakes. When you pull them, if possible save the bolts and spacers and make note where they go.
  5. hotrodhillbilly23
    hotrodhillbilly23
    from Indiana
    I've got a '39 chevy that someone put the whole frontend from a '51 -'54 under, crossmember and all, looks like a pretty simple install.
  6. Dan
    Dan
    curious to know about this as well, I have a '40 chevy p/u that I may try to put my '53 brakes under it...
  7. TomH
    TomH
    Yes……..It’s been years that I did that `53-`54 hub on `38 spindles. If I remember right you needed to drill the lower holes in the backing and take the spacers from the lower 53-54 and use them in the top and make longer spacers for the bottom bolts. You need the inside race from the `38 which will match up with the bearing from the `53 hub. That’s the way I remember it.
