Technical bent spindle
Discussion in 'The Hokey Ass Message Board' started by pimpin devil, Mar 8, 2016.
  1. pimpin devil
    pimpin devil
    from joplin mo
    I have searched the threads and can't find an answer to my question.when i was driving this t bucket home i noticed a left to right wobble on the tire well after i put the new wheels and tires on it looks worse so i jacked it up and spinned the wheel and its definitely not true and is doing it on both sides also noticed they have put a thin piece of metal and silicone over the rotor on one side tightened wheel bearings a hair to take out play still does same thing is this a bent spindle figured i would come here before i just rebuild the whole front end also you can hear it hit the pads at a certain point in the rotation.thanks guys for any help
  2. Pat Thompson
    Pat Thompson
    I would say more along the lines of rotor problem. If it was the spindle, the wheel would just lean and still run true.
    Hnstray likes this.
  3. Click to expand ^^^^
  4. bolt the rotor on tight and use a dial indicator and rotate and see whats up. no more guessing.
  5. pimpin devil
    pimpin devil
    from joplin mo
    I think i might have found the problem i believe the hubs are too big for the wheels will let you guys know thanks for all the help
