Best 32 Frame Rear 4 Link
Discussion in 'The Hokey Ass Message Board' started by 345 DeSoto, Jan 7, 2009.
  1. What rear 4 link set up seems to be the best in a 32 frame with a 9" rear and Stock '40 spring...not coil over? Looking for ride comfort, safety, generally the nicest all around system...
  2. Rob Paul
    Rob Paul
    Pete and Jakes style ladder bars.
  3. Do they make/sell only one style?...
  4. krylon32
    krylon32
    from Nebraska
    I did my 3 window with a buggy spring and P&Js rear 4 bar with the longer bars.
  5. 29Jay
    29Jay
    from Ft Worth
    Check out Riley Auto (vaphead) here on the HAMB. He has a cool little set up for the 4 bar and ladders.
  6. If you like the P&J style why not make some long 4-bars and mount them similar.
    Maybe 6"-10" vertical separation in the back and fairly close together at the front.
    Granted, not the instant center bit the drag racers like, but it should work well and IMO better than a rear radius rod.
    Something like the 4-bars on the front of this car.
    Home-Made 4-bars are easy to make.
    Polyurethane bushings are the way to go.
  7. yblock292
    yblock292
    not only that but hes an alliance member and a good guy to deal with, just bought a set of 32 rails from him.
  8. pasadenahotrod
    pasadenahotrod
    from Texas
    We used Posey's dual spring setup on the 3W COupe, easily done, rides gerat.
  9. HOTRODPRIMER
    HOTRODPRIMER
    I used the Pete and Jakes ladder bars on my 32 pickup,,,very traditional and a good look.
    I got a lotta parts from Eric,,can't say enough about his service. HRP
  10. I'm leaning toward fabricating an equal length, parallel, 4-bar set up, but not too sure about how far apart the bars need to be, what diameter to use, or how long is ideal. If I'm going to make them from scratch, I wondering if Heim joints would be strong enough. Fabricating a 4-bar set up doesn't LOOK like Rocket Science, but just leary that there's something I should know so as to avoid "catastrophic" failure. Fabing it up just looks too easy...
  11. screwshiney
    screwshiney
    i built my own set as well for my duramax. i did them 1.5" 1/4" wall and about 36" long. the longer the bars the less pinion change you will have throughout your suspension travel, providing you're making it adjustable. i think an ideal size for street rods is 1" or 1.25" and 3/16 or 1/4" wall. as far as the space between them try and get them either just outside of the axle or just inside and also make your panhard bar as long as possible to minimize side to side travel.
    some pics of mine
    http://s64.photobucket.com/albums/h197/1LOWDIESEL/truck/?start=180
  12. socal makes a nice clean set of ladder bars. paint em your self or get em chrome
  13. Dirty Dug
    Dirty Dug
    Pete and Jake's rear ladder bars are without a doubt the simplest and easiest route to take. Talk to Vaphead cause he's the best.
  14. krylon32
    krylon32
    from Nebraska
    While I used a long 4 bars and buggy spring on the 3 window, all my other deuces have P&J ladder bars. Looks more like a hotrod!
  15. model-a-fan
    model-a-fan
    from Kentucky
    Do you need a panhard bar with this set-up?
  16. Dirty Dug
    Dirty Dug
    No, not even if you're road racing. Pete and Jake's rear ladder bars provide a triangulated rear suspention and are good to 500 HP plus. A no brainer for anyone whose building a not so traditional '40s or '50s style car and wants dependability and function above all else. I fab different rearend mounts which move them up out of site. Also, I'm a big fan of the guys who go out of their way to build everything with traditional early Ford parts like '36 rear bones. Reinforced they can be very functional while looking the best with just a little more work and cheaper.
  17. Fenders
    Fenders
    Only if running coil-overs.
  18. Diamondhead
    Diamondhead
    from Kentucky
    I understand a transverse spring suspension does not need a panhard bar but does that answer change if it is a high arch spring?
  19. Sparkswillfly
    Sparkswillfly
    from Colorado
    Here's my setup.............
  20. Hot Turkey
    Hot Turkey
    Here's mine, 36 rear wishbones.
    [​IMG][​IMG][​IMG][​IMG]
