best bad paint excuse ever.....
Discussion in 'The Hokey Ass Message Board' started by Magic, Jun 11, 2009.
  1. Magic
    Magic
    Had a guy at the shop that was refered to us, and was having problems with the painter that was doing his car. After all the horror stories this guy has had and the car being at this guys shop for almost a year his painter who was on his 4th attempt at flaking the car finally gave the excuse.....
    "THE FLAKE IS COMMING OUT OF THE GUN UPSIDE DOWN, CAUSING IT TO BUNCH UP IN AREAS"
    I thought I was hearing thing and could not help myself and laughed at this one. He then had a couple of pics of the job and it is bad, probably the worst tiger striping i have ever seen.
    Any way had to share that one. SO be carefull of upsidedown flake.
  2. What would you think the problem was? I have heard many a painter talk about the problems of shooting flake.
  3. farmboat
    farmboat
    from Lucas, KY
    maybe you should just turn the flake over before you put it in
  4. Von Franco
    Von Franco
    He should of used A, universal velocity side mount whatyoumacallit sprayer, mine
    works every time ...........
  5. cleatus
    cleatus
    from Sacramento
    Easy fix. Just hold the spray gun upside down, then the flake will be coming out right side up.
  6. SinisterCustom
    SinisterCustom
    Sounds like he didn't use the double-sided flake.....that's all I use and it works like a charm....
  7. dirty petcock
    dirty petcock
    That's the problem with flake it's always coming out upside down. I have tried for years to fix the problem, but have not come up with anything yet. I have even flipped the car over in the booth, but even that gave me poor results.
  8. Magic
    Magic
    Hotrod --Most common problem with flake is to small of a needle in the gun for the size flake and no aggitation of the flake in the cup. There are guns just for flake but a lot of guys do not do enuff flake to justify buying a specialty gun.
    Farmboat-- Now we got to get the itty bitty tweezers out and turn all the flake, HaHaHa Thats funny
  9. BJR
    BJR
    The flake is not upside down, it's for the other side of the car! DUH It would be right side up if it were painted in China.
  10. James427
    James427
    You just have to take a large refrigerator magnet and run it across the "metal" flake in the same direction to turn it all over.
  11. Von Rigg Fink
    Von Rigg Fink
    from Garage
    put some butter on the other side of each flake..it will land on that side every time...and look fabulous
  12. That's the problem with using the cheap imported flake.
  13. 49ratfink
    49ratfink
    he obviously used gravity feed flake in a siphon feed gun.
  14. lippy
    lippy
    from Ks
    I think the flake is behind the gun. :p
  15. You mean a vacuum cleaner???? Hahaha...!
  16. username
    username
    You actual shoot flake a little different. Instead of shooting it at the surface you want flaked, you shoot straight up above the surface. By shooting up in the air the flake will gently glide/float slowly (like a feather) and land on the surface to be flaked.
  17. ... that's the best advice ever, butter the bottom side of the flake, everyone knows stuff always lands butter side down [​IMG] [​IMG]
  18. lownslow
    lownslow
    whaaaaaaaat ?
  19. kinglearjet
    kinglearjet
    Tiger striping is usually due to bad overlap, but like magic said aggitation and nozzle sizeis a serious consideration with big flake. Also If you lay it down really wet the flake can have a chance to float round and bunch up. It's not the easiest stuff to paint, admittedly
  20. G V Gordon
    G V Gordon
    from Enid OK
    Reminds me of an old joke. A forman was watching his new guy driving nails and about every third nail he would toss over his shoulder.
    "What the hell are you doing?" he asked.
    "Those nails have the heads on the wrong end", he replied.
    "Well dont throw'em away", said the forman. "We can use them on the other side of the house!"
  21. Dreddybear
    Dreddybear
    He needs the deluxe turbo encabulator gun attachment with adjustable marzel vanes.
  22. Evilfordcoupe™
    Evilfordcoupe™
    What color flake was it????
    Only certain colors will stand up too.
    -Jason
  23. Weasel
    Weasel
    It was Aussie flake from Tasmania, thus the Tasmanian Tiger stripes - when in doubt blame the Aussies - I do!:D
  24. 39 All Ford
    39 All Ford
    from Benton AR
    One time I was shooting some pearl and the pearl kept rolling off...
    I finally had to use some of that oblong pearl to get it to stay...
  25. Retro Jim
    Retro Jim
    I have had great luck with my process . I paint the car with extra thick paint so it takes a good while to dry . After I finish painting the car I take a handfull of the flake and sprinkle it all over the wet paint and get any design or pattern I want to . With the thick wet paint the flakes sink into the paint and it comes out great ! This method is so good if you miss a spot you just grab another hadfull of flake and fill in the bad spots you miss ! It's really not that hard to do ! :eek:
  26. Mike51Merc
    Mike51Merc
    Gee whiz, everyone knows you should only flake a car when it's rotated on the rotissiere.
  27. dynaflash
    dynaflash
    from South
    I get all my flake from Harbor Freight and I use a dryer sheet to prep the car. Never had any problems.
  28. Streetwerkz
    Streetwerkz
    that guy should have stayed at a Holiday Inn Express the night befor he shoot the flake..... everything would be alright then
  29. Tiger stripe flake is the new lace, craters of the moon flake was so last year.
  30. eddie1
    eddie1
    I thought we were done with the dryer sheet thread!:D
