Best carbs to run??...2x2
Discussion in 'The Hokey Ass Message Board' started by Clark, Mar 10, 2006.
  1. Clark
    Clark
    I've got a 2x2 intake for my 57 Packard 289. Right now it's set up for 4 bolt carbs. The carbs that are on it are Carters. They are junk. What's the best carb to run?
    I've got 3 Stromberg 48's, but I hate to use just 2.
    What about the Stromberg aerotype carbs?
    What about the carters?
    Clark
  2. zman
    zman
    from Garner, NC
    If it's four bolt throw some 2GC's on there....
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    One good point about the aerotypes is that I think they use the same main jets as 97s, so fine tuning them should be no problem.
  4. Sixcarb
    Sixcarb
    from North NJ
    Not sure how well they work but the early 50's Lincoln carbs are 4 bolt and they look pretty cool, I'll see if I can dig one out this weekend and see what the measurement of the bolt pattern is if you would like. I'm pretty sure I have on somewhere....I hope.
  5. Clark
    Clark
    2G's won't work. I'm want to use the flame arresters I got with it. They fit the smaller carbs.
    Clark
  6. SUHRsc
    SUHRsc
    sell me a 48 ...then you'll only have 2 and it wont be a problem
    ive seen people bore out the 4 bolt merc carbs to get more cfm's...maybe 2 of those if the motor is bigger?
    good luck
    zach
  7. 286merc
    286merc
    from Pelham, NH
    Early 2G's with the small base (Zillions on 265/283 Chevys), Holley or Carter from 318 Mopar, Backdraft Holley from 49-51 Merc/Lincoln (thats the funky one), or even the Towering Inferno Ford/Holley from 52-3 Merc. Older would be the Stromberg AA used on Buick inlines and others.
  8. tommy
    tommy
    I don't know what is the best, but I'm going to run 2 of these Stude Stromberg WW carbs just because they look so strange. Small problemo...No room for a conventional air cleaner.
    Stromberg made the straight up variety WW that will bolt right on also. I've got 2 97's with adapters on my Stude engine now. They work great. I just like a carb that is bent 90 deg. in the middle!:D
    Here is Ratbastads post about the straight variety.
  9. InjectorTim
    InjectorTim
    My Buick came with an aerotype on it I never used it so I can't say too much about them, I don't know if it is of any interest, but here is what the inside of an Aerotype looks like.
  10. Flat Ernie
    Flat Ernie
    Tech Editor
    Why not run the Holley's from T-bird or Merc? Here's a pair on an Edmunds Racing intake...
  11. 286merc
    286merc
    from Pelham, NH
    Thats the Holley Model 1901 Towering Inferno I mentioned. Only used on 52-3 Merc flatheads and 52 Lincoln. The Merc, later Lincoln and T Bird Y Blocks used a 4 bbl version, the Holley 2140 & 4000 until 57.
    That backdraft I mentioned is a Holley 885.
  12. sidevalveguru
    sidevalveguru
    I'd love to see any pix/info on this!
  13. George
    George
    In theory you need apx 460 CFM. 2 48s are 350 CFM. The Ford 351C-2V carb is rated @ 350 CFM & they seem to move along OK.
  14. Dick Dake
    Dick Dake
    With that being a Stude motor, Stromberg WW6 are the stock carbs, 2 should work. I think that's what Paul had in his then Stude powered T.
  15. Flat Ernie
    Flat Ernie
    Tech Editor
    This thread is over 2.5yrs old...
  16. George
    George
    Who says the dead are returned to life only on Halloween?:p
  17. dickster27
    dickster27
    from Texas
    Clark I have some 4 bolt 94's that are just the ticket for that intake. Pm me if your interested. I think they would be the perfect size also for the engine.
  18. Clark
    Clark
    I've since gotten rid of the motor and intake.
    Clark
