Technical Best Chassis Paint?
Discussion in 'The Hokey Ass Message Board' started by Dylan Pelton, Nov 28, 2018.
  1. Dylan Pelton
    Dylan Pelton
    I'm looking for a ch***is paint for an off topic project, but i want it to be the best of the best. I have used a lot of products in the past that I have been disappointed with, and didn't hold up very long. I know powder coat would be the best choice but the ch***is is going to get body worked so that is out of the question. I'm looking for satin or ch***is black that can be sprayed. Any suggestion, or any products to stay away from?
  2. 1-SHOT
    1-SHOT
    from Denton
    Check with your powder coater , I believe there is a filler available to be coated over.
  3. bubba55
    bubba55
    Rustoleum black that I got at hardware / Lowes - cut it with 10% mineral spirits - sprays great - used it on my '38 chevy twuck and '30 A frames - no complaints
    31hotrodguy likes this.
  4. LOWDUG37
    LOWDUG37
    X2
  5. da34guy
    da34guy
    SPI Epoxy.
    metlmunchr likes this.
  6. oldolds
    oldolds
    Rustoleum works fine for that. There is a regular ch***is paint that is used on most OT cars from factory. Kind of thick rubbery. If you are doing something that needs to be correct.
  7. Dylan Pelton
    Dylan Pelton
    I'll check out the SPI as I'd like to use a higher quality product. It doesn't need to look factory correct just a nice smooth satin black.
  8. earlymopar
    earlymopar
  9. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
  10. whiteknuckle
    whiteknuckle
    from Dryden, NY
    Check out PPG Delfleet Essential. I have used is numerous times in automotive and motorcycle ch***is application. Flows out great and is highly durable. It is high gloss but I would ***ume it could be used with the PPG SLV4985 flattener to get the desired gloss level.
  11. Fortunateson
    Fortunateson
    Up here we have Tremxlad which Ithi k is the same as Rustoleum. 75% flat and 25% gloss will give exactly what you want. How the right look and very durable.
    trollst likes this.
  12. Dylan Pelton
    Dylan Pelton
    I have seen that stuff before, seems pretty good. have you used it personally?
  13. rusty rocket
    rusty rocket
    I have used hirsch engine paint several times, just ordered a quart of ch***is paint sprayed my banjo rear end with fair results. Thing that Erks me is hirsch bends you over on there shipping.
  14. earlymopar
    earlymopar
    Yes, both engine and frame paint. Rocket is correct however, their shipping costs are higher than they should be.
    - EM
  15. da34guy
    da34guy
    SPI is FREE freight by the way.
  16. 64-classic660
    64-classic660
    From my experience with paint, I’d go with a flat paint Rusto works great. Prep the surface with mineral spirits cut with thinner. Use a clear coat for desired gloss level. Could probably get away just using rattle cans for the clear.
  17. chopolds
    chopolds
    from howell, nj
    You need the toughest paint you can get for a ch***is. First choice would be Imron. Second, Master Series or POR-15 Ch***is black (the topcoat stuff, NOT the rust encapsulator)
  18. Fat47
    Fat47
    You didn't say what your doing to the frame before painting. Sandblast???? Chemical dip???? Sanding rough spots only????? What you paint over makes a huge difference.
  19. depends on desired result
    a driver thats going to be wire brushed/loose rust scuffed.......use the rustoleum/tractor supply stuff
    if its getting blasted, PPG has an industrial epoxy and a semigloss that looks great and doesnt hurt the wallet
    clem likes this.
  20. brady1929
    brady1929
    Great info here, thanks.
  21. Bandit Billy
    Bandit Billy
    Hey, you guys stick Chevy motors in your fords, might as well make 'em feel at home!
    Seriously, this is great stuff and the matte finish is perfect.
    Tickety Boo and waxhead like this.
