Best cost on adjustable coil-overs?
Discussion in 'The Hokey Ass Message Board' started by earlymopar, Oct 23, 2008.
  1. earlymopar
    earlymopar
    I'm looking for someone who sells ride height adjustable coil-overs for a Mustang II style front suspension. I know, not HAMB-like but that's what I have for now.
    I don't want chrome anything just painted springs and shocks and a good price. I'd appreciate your recommendations on who to buy from and what brand they carry. If you know their cost, that would be helpful too.
    Thanks much,
    - EM
  2. earlymopar
    earlymopar
    Any help guys?
  3. Retrorod
    Retrorod
    The only ones for that application that I know of are QA1. I tried them on my '35 w/Must II, after a year of screwing around with springs...adjustment and the like, I finally took them off when they started leaking oil. I never got the front end to work decent until I used stock Ford springs and regular shocks.
    The QA1s are under the bench where they belong.
  4. There are a lot of racing supply companies that sell coilovers for a good price. The trick is going to be finding any short enough to fit the MII suspension. Try Speedway, can't hurt...
  5. blackmopar
    blackmopar
    from fallbrook
    fatman specs carrerra - what i got on my front end, but theyre (eek) chrome
    also dont rememebr what brand alston uses, but beleive theyre on his site - maybe qa1 also
    speedway is a good recommendation also
  6. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I've got Aldan Eagles on the back of the Burb. Best price I've seen, seem to work fine. Have maybe 400 miles on them.
  7. earlymopar
    earlymopar
    Thanks for the feedback, suggestions and comments guys.
    Retrorod, when you said you "never got the front end to work "decent", what problems were you having? Shock or spring related? I realize that you were prpobably frustrated after a year of messing with them and they certainly shouldn't leak that soon but aren't the QA1s rebuildable to fix the leak issue?
    Exwestracer, I had done some checking on race application coil overs earlier and you're right about the length / travel issue. Some road race stuff is close.
    - EM
  8. llonning
    llonning
  9. Da Tinman
    Da Tinman
    QA1 stuff is hit or miss if you got a good set they will last forever. I have pulled a new set out of the box and they were already leaking.
    Shame really they bought a good company and rather quickly turned it to ****.
  10. earlymopar
    earlymopar
    That is interesting Tinman. I'm curious is they are rebuildable the way that Koni's are?
    llonning, I did give Art Morrison's a look and found Aldan Eagle, Strange Engineering and AME coil overs. The AME units are 1/2 the cost although I can't see if they are made for both front and rear applications. I'm checking with them now.
    - EM
  11. Da Tinman
    Da Tinman
    Yep rebuildable, but I would look elsewhere.
    I know the guy that built the company they bought out. (Hal) First thing they fired him and his wife. Then they canned most of the tech and support people. Next quality went to hell. Oops what do we do,, we dont have anyone that knows how to fix it.
    Not a Fan!
  12. Retrorod
    Retrorod
    The problem is......for a MII front end you just can't stick any old kind of coil-over in that front end......no room. The QA1s fit the application very well but the bee-hive springs are short and not available in enough of an ***ortment of weights.
  13. earlymopar
    earlymopar
    Hey Guys:
    I heard abck from Art Morrison on the AMEs and unfortunately, they are only for rear end applications. They did tell me that they have sold many of the Aldan Eagle units but they are $415.00 plus shipping costs with the spring. The larger draw back is that due to design constraints they only have 2.5&#8221; of total travel, less when you include the bump stop. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p> </o:p>
    <o:p></o:p>
    <o:p>Any of you know the travel on coil overs that you have used or researched?</o:p>
    <o:p></o:p>
    <o:p>Thanks,</o:p>
    <o:p></o:p>
    <o:p>- EM</o:p>
  14. brandon
    brandon
    isn't HAL doing the versa shocks with chris alston...?
  15. Da Tinman
    Da Tinman
    Hal did the Vari-shock, Vari-struts for drag racing, Great product! The Shockwave bag shock combo is his, He stays busy and is a real good guy. Not sure on the Chris Alston thing, I havent talked to him in a while.
    Edit: brain fade, yes Varishock is with Chris Alston, in fact we used the one of the first sets of the struts on the Cavalier we built. http://www.datinmanjay.com/alexh.html
    (sorry for the derail)
  16. I've got this same issue. I've used QA's before & have them on 1 car still. I like em, but to buy a set alone is half a grand. I don't really like that part. Carl Hagan
  17. llonning
    llonning
    earlymopar, If you can talk to Dave Jones or Craig Morrison. Used to work with them. They will give you the straight poop.
  18. Russco
    Russco
    from Central IL
  19. OSHR
    OSHR
    Call the guys at Romic 760-244-4478. Best coilover on the market and they can and will make the shocks to your specs. Ask for Mike or Roger.
  20. earlymopar
    earlymopar
    Thanks again for all of your comments and suggestions guys. I'll certainly get back to Art Morrison and will check with "Romic" and "ARS". Once I have more, I'll reply.
    - EM
