Hot Rods Best dash in a model A , show us yours
Discussion in 'The Hokey Ass Message Board' started by shonky, Jan 29, 2010.
  1. -Brent-
    -Brent-
    Chrome 36 Dash In Model A Coupe.jpg 36 Ford Dash Back from Northwest Chrome .jpg
    Chromed 35/36 dash in my A
  2. Stock '29 dash for speedo, oil pressure, volts and fuel gauges with horn ****on where the dash light was. Overhead is the water and trans temp gauges flanking a 3-3/8 inch tachometer, left, right turn and high-beam indicator lights, ignition, lights and hazard switches. I didn't want anything cluttering up the now-gutted fuel tank area.
    dana barlow and Okie Pete like this.
  3. hotrodjack33
    hotrodjack33
    Narrowed '32 Pickup dash in my old "31 Slantwindow.
  4. Stan Back
    Stan Back
    Don't see many with a fuel pump anymore. This one was there for the 6 carbonators.
    Okie Pete likes this.
  5. Stan Back
    Stan Back
  6. '29 Gizmo
    '29 Gizmo
    from UK
    Just about to put this one in. I wanted to retain the original aesthetic. Light switch is early Jaguar. Warning lights are temp and charge.
    CSPIDY, X-cpe, dana barlow and 3 others like this.
  7. Kiwi 4d
    Kiwi 4d
    Holy schmoly @-Brent- those windscreen curved turn up corners to the A pillar are tricky enough to fabricate anyway ,let alone chrome. And the vertical returns to the A pillars , sheesh . And you removed the window crank hole in the waterfall . WOW.
    Just Gary and 05snopro440 like this.
  8. 05snopro440
    05snopro440
  9. Bandit Billy
    Bandit Billy
  10. -Brent-
    -Brent-
    Thanks! The waterfall is from a vert or cabriolet. They didn't use window cranks. I bought a pair of them when the prices weren't insane.
    Thanks!
    HAHAHA!
  11.
  12. Blake 27
    Blake 27
    Capture A.JPG Model A and Angela at tree 002-2.jpg My brother Tom's Street A from 1980...
  13. Turbo26T
    Turbo26T
    '29 Buick ...Width is perfect and upper curve follows the ModelA dash closely... IMG_1887.jpg
    osage orange likes this.
  14. dana barlow
    dana barlow
    from Miami Fla.
    Upper dash rail,had a few extra holes plus 2 rust holes. So I replaced it with homemade wood. Dash is just speed-o n water n oil,with light switch. 014.JPG
    osage orange, CSPIDY and X-cpe like this.
  15. lostone
    lostone
    from kansas
    What started out as a 38' ford dash panel, mix in 35 to 40 hours labor and I ended up with this.
    The gauge panel comes out from the back side and will have gl*** between the gauges and dash panel...
  16. X-cpe
    X-cpe
    Still in progress for the coupster. Bead roller and a hammer form for the basic shape. Home made dies for the beads around the gauges and indicator lights. Lower edges of the dash and door caps align and the ends will roll into each other. (right side started) Still have to figure out the transition to the windshield posts. The tach will be to the left of the speedo and mounted to the steering column.
    48stude, Turns, osage orange and 3 others like this.
  17. clem
    clem
    Just absolutely beautiful ! ! !
    The thread ***le says ‘best dash in a Model A’, - I think you just showed us the best one.
    Best looking dash that I’ve ever seen !
    Thanks for sharing.
    ( ps - couldn’t quite figure out what was written on the wooden header panel above).
  18. Flatrod17
    Flatrod17
    This is what I came up with for my brother's 29 roadster. Much modified 41 dash 40 gages.
    akoutlaw, osage orange and X-cpe like this.
  19. Blue Moon Garage
    Blue Moon Garage
  20. flthd31
    flthd31
    My 30 coupe with 35-36 dash. That's an old school courtesy light in the crank hole of the waterfall which I chose to leave unrestored.
    ne'erdowell, X-cpe, -Brent- and 4 others like this.
