Best grease for control arm bushings
Discussion in 'The Hokey Ass Message Board' started by pzofsak, Aug 8, 2013.
  1. pzofsak
    pzofsak
    from texas
    I am about to replace the front control arm bushings on my project and wanted to know if it is advised to grease the sleeve inside the bushing? If so, what kind of grease, axle, white lithium, etc? Thanks in advance.
  2. What kind of bushings? (the material they are made of)
  3. fsae0607
    fsae0607
    Chassis/Wheel Bearing grease.
  4. JohnEvans
    JohnEvans
    from Phoenix AZ
    If it is a rubber bodied bushing no grease is needed ,a thin film of oil to aid assembly is all that is needed. Metal to metal use regular chassis grease.
  5. dkendall
    dkendall
    What about urethane bushings that sgueek?
  6. pzofsak
    pzofsak
    from texas
    These are rubber bushings with a metal sleeve insert.
  7. No oil or grease.
    Petroleum tends to emulsify or "break down" the rubber over time. So keep it clean and dry.
    If you are installing new bushings in stamped control arms, a very light application of anti-seize will help installation.
    zzford likes this.
  8. pzofsak
    pzofsak
    from texas
    The grease would be on the inside of the metal sleeve where the pivot rod goes through; basically metal on metal.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    There is no pivot action there so no grease is needed. If you look closer at the inner sleeve you will see saw tooth type ends, these bite into the pocket where the bushing install's. Want does pivot, so to speak, is the rubber twist's. This is why you should leave all bushing bolts semi loose and put the vehicle back on the ground on it's tire's so A-Frames are at ride position. Then you tighten your bushing bolt's.
  10. OldFord39
    OldFord39
    from Monroe, Wi
    If you have a squeak or want to pre lubricate I would recommend
    Molykote
    ® G-5881 It is made by Dow Corning it works great.
  11. gnichols
    gnichols
    from Tampa, FL
    Good to know stuff. Gary
