best intake for 302/AOD?
Discussion in 'The Hokey Ass Message Board' started by tiptopdadddy, Nov 1, 2005.
  1. tiptopdadddy
    tiptopdadddy
    from INDY
    At the recommendation of another HAMBer I moved this over from questions and suggestions. Thanks in advance guys.
    I am making out my Christmas list. With that in mind, I need an intake manifold to top off a 1978 Thunderbird 302 using stock heads, rods, cam and an AOD trans. I was looking at some late model Mustang and Edelbrock intakes and carb combinations, but I'm just a little confused. Some sources say I need a Lokar linkage while others say an AOD won't work at all. But I know Ford used this combo a lot.
    This is going into a '51 F-1. I want a reliable daily driver with some balls for towing my camper or draggin' on main street.
    Any recommendations?
  2. bad gas
    bad gas
    you might check out an 85 mustang. the early 85 used a 4bbl carb with a aod trans.maby similar linkage. just a thought
  3. AnimalAin
    AnimalAin
    The Lokar stuff works fine. I've had it on my coupe with a 351W/AOD for ten years. Make sure you read the instructions, and that the linkage has no slack in it.
  4. Da' Bomb
    Da' Bomb
    This is an easy swap. My favorite....Use the Lokar Throttle valve kit. Just follow the instructions to the letter, otherwise you plan on a cooked tranny within a block if the pressure is not set correctly. Been there, done that. So far as an intake goes...anything your heart desires...1X4, 2X4, 3X2, homemade 6X1. Doesn't matter. The only thing thats important is the TV pressure.[​IMG]
    Cheers,
    Pat
