Projects and timing. Never shall the two meet with money in hand. Either way, any recommendations for a machine shop in Texas. I am located in Houston, but will travel. The project in question will be a highly modified T block. Thanks.
Calvert Machine in Denton. Been around for a very long time. Sent from my Moto G Play using The H.A.M.B. mobile app
What kind of work do you need? Standard rebuild or all out race motor? All in Houston: Faerman facing engines. Westside performance (I've used them - good) Whatleys automotive. Scroggins automotive Llano- Texas engine machine There's a shop in college station that knows old motors but I don't remember the name
Going to start with the rotating assembly. Need a shop knowledgeable in the ways of installing insert bearings. If that is a no go, will have to find a place to rebabbit the mains, which is a whole different kettle of fish. On the easier side, need to have the crank finish machined, as the first part was done (shortening), now it needs to be finished (bearing surfaces, radii, etc). The easier bits like installing valve seats and valves and decking everything is pretty straight forward. I will end up building the pressure mains if I go that route. Don't plan on reving much past 3.5k anyways. Thank you.
