Best model A front crossmember?
Discussion in 'The Hokey Ass Message Board' started by Shifty Shifterton, Dec 14, 2006.
  1. Shifty Shifterton
    Shifty Shifterton
    Help a guy out here, I'm having a hard time finding what I'm looking for, even though they're everywhere. :mad:
    I'm looking for a repro model A front crossmember that's original style. Doesn't have to be exact, but can't be tubular steel either. Every used one I find has stress cracks, and am not too cool on building around a stress cracked piece and chasing small fractures for the life of the frame.
    So now looking around and see all kinds of crossmembers like this in various people's reproduction frames. But no repro crossmembers seperately. Only one I have found advertised is speedway, and it's a lowering crossmember, but I need something closer to stock height.
    So if you can point me in a direction here, that would be great. If you could provide commentary on a specific maker's metal thickness or overall quality, that would also be cool.
    Thanks for readin!
  2. VAPHEAD
    VAPHEAD
    I sell the CE crossmember a**** others.
    I like it best because it can be used in a stock frame.
    Not only a boxed frame like others.
    Stay away from the Speedway one it's junk.
    .02
  3. Shifty Shifterton
    Shifty Shifterton
    CE = Ch***is Engineering?
    Thanks for the info!
  4. krylon32
    krylon32
    from Nebraska
    I've used lots of Deuce Factory front crossmembers. They have 7 degrees of caster built in.
  5. Shifty Shifterton
    Shifty Shifterton
  6. i think curator may have one.
    executioner
  7. Sutton
    Sutton
    from BTR
    Got mine from Pete and Jakes, 7 degrees caster built-in, around 80 bucks.
  8. VAPHEAD
    VAPHEAD
    CE = Ch***is Engineering.
    Duece factory,thats the standard short one.Boxed frame only.
    CE,is $75.00 and about $12.00 shipping in the USA.f.y.i.
  9. Royalshifter
    Royalshifter
    Moderator
    Buy from Eric, Riley auto. Alliance vendor.
  10. silent rick
    silent rick
    is this a stock height application or will it lower the front end?
    how much can you lower the front by modifying the crossmember without having to notch the frame rails for spring clearence?
  11. VAPHEAD
    VAPHEAD
    It's a copy of the Model A.
    Will not lower a Model A frame
    Will lower a 32 frame.
    Won't need to notch.
    Can go with a flat style A cross member $99.95 but you will need to notch.
    Does that help?
  12. silent rick
    silent rick
    sure does, thanks. i didn't see any on your site, but you still sell them, right?
  13. VAPHEAD
    VAPHEAD
    I have a ton of stuff to add to my site.I'm just a slow typer.
  14. orcas tow
    orcas tow
    Got mine from VAPHEAD, good price & quality.
  15. seymour
    seymour
    from PNW
    Eric rules! He answers all my dumb questions about parts he sells!
  16. A Boner
    A Boner
    Does the CE "A" crossmember have the 7 degree caster built into it, or do you have to weld it in at an angle in the frame to get the proper caster?
  17. Shifty Shifterton
    Shifty Shifterton
    Wow, small world. I just found Riley's last night googling and had no idea it was Eric from this thread/board.
    Seymour, you're totally right too, he gave me a well thought out response to my stupid questions about a complete front-end kit. Thanks Eric.
    For what it's worth I bought a Ch***is Engineering crossmember this morning. Will be using rectangular tubing for side rails so original side rail fit was not a selling point.
    Got to talking with the CE tech guy, and he mentioned their crossmembers are made by the deuce factory. Didn't say if it's the same, or if it's made to CE spec. Interesting though.
