Technical Best original ford cross steer for Model A?
Discussion in 'Traditional Hot Rods' started by 28fordroadster, Mar 10, 2023.
  1. 28fordroadster
    28fordroadster
    Model A frame, roadster cowl, 8BA mounted far enough forward to mount 29 cowl without cutting the firewall. Two choices of cheepo headers. I'm going to mount the radiator 1.5" forward to clear the truck fan. I have a dropped main spring on a 33-36 axle. I have 42-48 square back spindles.
    What are my choices for cross steer steering boxes that are stock ford?
    I am considering cross steer because of the dwindling availability of the F-1 box
    Thanks for your help
  2. alchemy
    alchemy
    F-1 boxes are hard to find now? I was at a swap meet last weekend and saw maybe a half dozen. Granted, they will surely need a rebuild.
    -Brent- likes this.
  3. wheeltramp brian
    wheeltramp brian
    On my model A high boy I used a 46 Ford crossteer box
    oliver westlund likes this.
  4. Tim
    Tim
    from KCMO
    Got a 46 on mine as well
  5. 28fordroadster
    28fordroadster
    Brian and Tim Thanks for your reply. Can you send pictures? How is the header clearance?
    Thanks
  6. 31Apickup
    31Apickup
    1937-1948 Ford p***enger car boxes.
  7. Tim
    Tim
    from KCMO
    It mounts pretty far forward so generally no trouble. I’m not running a flathead v8 but I’ve seen plenty running the combo. I’m using the box to frame bracket as well with a little spacer. I don’t have time now for a picture but I’m sure there’s to many and to much info in my model A build thread if you click on my profile there’s a link
  8. dwollam
    dwollam
    F1 is not a cross steer anyway. My Avatar '29 has a '40 axle and steering.
    Dave
    gimpyshotrods and Tim like this.
  9. rusty valley
    rusty valley
    32-34 boxes work well in a model A. You use the A sector housing, then its a bolt in
  10. manyolcars
    manyolcars
    My plan is a 40 pickup steering column/box
  11. Corn Fed
    Corn Fed
    F1 boxes aren't hard to find. Finding ones that have good internals is tough. But you are going to have that same problem with your cross steer box too. In fact, the guts from a 37-48 cross steer are the same as an F1. So if you luck out and find a good cross steer, you can swap those into an F1.
    randombob, clem and Asphalt Demon like this.
  12. el Scotto
    el Scotto
    from Tracy, CA
    No kidding?! Learned something new today!
    clem likes this.
  13. Atwater Mike
    Atwater Mike
    Me too... (just happen to have enough to do one!)
    Thanks, @Corn Fed!
  14. 28fordroadster
    28fordroadster
    Corn Fed.. I heard that the internals could be swapped.
    If anyone has pics of a cross steer box mounted to a model A frame I would love to see them
    Thanks for your comments hambers! I appreciate it
  15. D Newcomb
    D Newcomb
    With the loss of MAC's / Ecklers the worms and steering box parts are unabtainium. Our local machinist/rebuilder of steering boxes is stumpted [Oregon]. Caution on using those old boxes now. Newc
    HellsHotRods and oliver westlund like this.
  16. oliver westlund
    oliver westlund
    Im doing the same and would love to see pics as well
  17. el Scotto
    el Scotto
    from Tracy, CA
    He must not be very internet savvy or just doesn't want to work on them, because the sky is not falling... ;)
    Everything but the worm gear 7HC-3524-X is currently available at Dennis Carpenter:
    https://www.dennis-carpenter.com/trucks/steering/steering-box/20/1/2/
    CPP is making the worm gear new, part number 4852WG
    https://www.ebay.com/itm/264968441264
    There's other places offer whole kits, although sometimes expensive.
    https://www.cl***icperform.com/ whole kit part number 4852SOK
    https://www.f100central.com/48-52-steering-box-rebuild-kit.html
    https://www.jamcosuspension.com/product/1948-52-ford-truck-manual-steering-box-rebuild-kit-4852sbk
    https://www.cmwtrucks.com/product/48-52-ford-truck-steering-box-rebuild-kit/
    Nailhead A-V8 likes this.
  18. Mr48chev
    The trouble with Macs/Eckler is You spend hours looking for the pieces that others might have in a kit. Or if you need a set of something you have to remember to order X number to make that set or you just get one.
    The problem with most all post 1948 car steering boxes is that the gear box with the worm and sector sits on top of the frame rail with the housing/bracket that the sector shaft runs though bolting to the inside of the frame rail below it. Not a big deal with a fat fender where you can hide it but rather ugly on an earlier rig. 268.90 for a worm and sector plus the cost of bearings, seals and gaskets plus the cost of the going price of a fair to middling F-1 Box and you have 500 Bucks tied up in an old steering box. Same cost for a 37/40 Ford box after you rebuild it I'd have to think.
    I've got good 47/54 Chevy truck boxes sitting around but they look like **** sitting up on top of a frame where you can see them. Too much exposed ugly.
  19. Illustrious Hector
    Illustrious Hector
    After having one rebuilt and modified by him, I would highly recommend NealinCA on here, Atascadero,CA,
    Blues4U likes this.
  20. alchemy
    alchemy
    Heck, Nealin makes brand new steering boxes that might even bolt in.
  21. A good resource is "This Old Hot Rod" on YouTube. Watch the "27 Ford Roadster" series. Somewhere around episodes 5, 6, 7, or 8 he shows how to install a Ford cross steer setup. He is using an "A" frame. I just installed a 1937 Ford cross steer box and column using This Old Hot Rod's instruction and it turned out good, but I'm running a straight six, so clearance was better. One thing to keep in mind, and someone correct me if I'm wrong, when you use side steer it may give you clearance and will put the steering torque forward to the axle, but when using cross steering it side loads the frame rails and can cause frame rail twist. I personally have experienced the frame rail twisting in my setup. My setup drives down the road really nice, but I am worried about the frame getting side loaded at full lock. You will have to use the correct bracket or box the frame rail near the box to mount properly, and before we go down a rabbit hole, I do not believe in boxing the entire frame, unless the engine is very heavy, or the engine has excessive torque/horsepower. Just my opinion which really means nothing. But for the purposes of this conversation, the 37-48 cross steer box and column will work. A 46 Ford truck has cross steer too, so other years on trucks will apply to finding a box and column. different years will have different column lengths and steering wheels. Choose your setup based on style and length. The columns are different at the base of the steering wheels throughout the years, but the splines should interchange up to 48. I believe the splines changed for the '49 model year. Hope this helps.
