Best Penetrating Oil?
Discussion in 'The Hokey Ass Message Board' started by daredevilcustoms, Feb 9, 2009.
  1. Truckedup
    Truckedup
    I've used them all,PB,Kroil etc.But nothing beats the 6000 degree torch.
  2. Mike51Merc
    Mike51Merc
    Sorry, I can't resist:
    So, where do you get your "Nuts Off"?
    I get my "Nuts Off" at the local auto parts store.
    Nothing's better than getting your "Nuts Off" at a good price.
    It's been a long time since I got my "Nuts Off".
  3. rustyford40
    rustyford40
    from Mass Bay
    I hide my can of kroil so no one will use it. Yea i'm that kinda guy.
  4. strombergs97
    strombergs97
    Great idea, your so right about the pressure being lost. Thanks, I never thought about doing what you said..
    Duane.
  5. NITRONOVA
    NITRONOVA
    Not sure why the bolt/nut gets hot when turning. All I can say is that it gets warmer than when I use other penetrants (upon removal). Spray soak.......spray then remove. I have a buddy working in a Honda shop (car line) and I got him on the stuff. He won't be without it. All the GM guys in the shop next to the Volvo shop I used to work in keep a can in their box too.
    All I can say is , it is by a huge margin the best I have used!:)
  6. fitty_2
    fitty_2
    I vote for PB.
  7. B.A.KING
    B.A.KING
    make my own,****** fluid thinned down with accetone.
  8. lostn51
    lostn51
    from Tennessee
    I restore vintage sewing machines 1860's-1920's and what I use on them is a mixture of Royal Purple and Kerosene mixed 40/60 (60% Kerosene) in a spray bottle and it works better than anything I have ever used. Sewing machines are very delicate and the finishes on some of the super rare ones you do not want to damage especially the decals/ornamentation, and it will not harm the finishes. I have taken a 1900 model 24 Singer chain s***ch that was locked up tighter that ****s hat band and after soaking for a day or two it was freed up, and after a thorough cleaning it was sewing like it was brand new.
    After I started using this mixture I threw out my PB Blaster, WD-40, and Kroil.
  9. loranzo46
    loranzo46
    from pa
    ZEP 45 works awesom. Spray it let it soon for a min or two. It does cost a little bit more but its the best out there.
  10. attastude
    attastude
    pb blaster...(panther piss)
  11. MERRELL
    MERRELL
    ive had good luck with seafoam's "deep creep",its like 10 bucks a can:[
  12. monster
    monster
    used to use pb, then found out about this stuff
  13. Dyce
    Dyce
    I have put carbs in the oven to get jets out. I set it to 250 degrees, take it out, soak it with oil (I like Justice Brothers), and let it cool. If it dosn't come loose I just put it back in the oven and start over. I have to admit it does make the pizza taste funny if you don't air it out.
    Jeff
  14. chilimac
    chilimac
    Kroil works best, Zep 45 works really well and is also a great lubricant.I've worked in aviation for a long time and these two will remove turbocharger hardware that laughs at Mouse Milk.
  15. RichG
    RichG
    When Kroil doesn't cut it I just get out my little pop-pop tin of Marvel Mystery Oil, soak the part, then come back the next day. Hasn't really failed me yet.
  16. The37Kid
    The37Kid
    Finally got the door hinges off the cowl of my '30 Ford Roadster. PB Blaster didn't work so i did a 50 - 50 mix of acetone and ATF. Five of the ten screws came out with a Dewalt hammer drill. The others had to be center drilled, and turned out with an Easy Out.
  17. Again Kroil is #1 BreakAway close second.
  18. old beet
    old beet
    Astro Glide...Damn it on the wrong site again, sorry!
  19. superbeeme
    superbeeme
    from georgia
    It only took 74 posts for someone to get it right!!! Kroil works best, Zep 45 works really well. :eek:
  20. superbeeme
    superbeeme
    from georgia
    I've also used brake fluid at times, for a broken bolt I drill out with a left handed drill bit. MY .02.
  21. saltgrassdrifter
    saltgrassdrifter
    I got this off another site
    Penetrating Oils
    <HR SIZE=1>A friend sent this to me. Thought I would p*** it along.
    Some of you might appreciate this. Machinist's Workshop magazine
    tested penetrants for break out torque on rusted nuts.
    They are below, as forwarded by an ex-student and professional
    machinist, Bud Baker.
    They arranged a subjective test of all the popular penetrants
    with the control being the torque required to remove the nut from
    a "scientifically rusted" environment.
    *Penetrating oil ..... Average load*
    None ...................... 516 pounds
    WD-40 ..................... 238 pounds
    PB Blaster ................ 214 pounds
    Liquid Wrench ............. 127 pounds
    Kano Kroil ................ 106 pounds
    ATF-Acetone mix..............53 pounds
    The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic
    transmission fluid and acetone. Note the "home brew" was better
    than any commercial product in this one particular test.
    Our local machinist group mixed up a batch and we all now use
    it with equally good results.
    Note also that "Liquid Wrench" is about as good as "Kroil" for
    about 20% of the price.
  22. fearnoevo
    fearnoevo
    from Iowa
    Kroil for me......
    1964 Bel Air ball joints, couldn't get them loose with a 3/4 impact. A couple of drops of Kroil and a cigarette later, they came off with a hand wrench.
    Still have the same gallon I bought almost 20 yrs ago for that Bel-Air
  23. gaskell
    gaskell
    from CO
    Kroil... hAnds down.
  24. indyjps
    indyjps
  25. Ron In the SHOP
    Ron In the SHOP
    from california
    ATF / acetone...
    and tap the thing with a lead hammer.....
  26. Kan Kustom
    Kan Kustom
    thats what i was looking for !!!!! Thanks !!!!
