Technical Best permanent marker?
Discussion in 'The Hokey Ass Message Board' started by Ziggster, Apr 1, 2025.
  1. Ziggster
    Ziggster
    Tried various “permanent” markers over the years. Disappointed with most I’ve tried including the latest which was some Milwaukee ones. What do you use that works and stays on? Challenge is in sub-freezing temps and oils/liquids.
  2. Dreddybear
    Dreddybear
    Sharpie pro
    Edit: Not sure about the freezing temps. We don't get those here.. but they are super stinky wet markers.
    lemondana and abe lugo like this.
  3. BJR
    BJR
    I use the paint markers for parts I am storing or going to swap meets. I don’t think anything will work in sub zero temperatures.
  4. Admiral Tom
    Admiral Tom
    Nothing is really "Permanent"...even etching or stamping can be ground off. but like BJR said, try the oil based paint markers (they have acrylic ones also, but they are not as "permanent"). Here's a link to some...ref=sr_1_8.htm.
  5. K13
    K13
    Nothing is going to work really well sub zero or in oil. Oil would be, as mentioned, a paint marker but they tend to be pretty co**** tipped so depending on what you are marking they aren't great either. Milwaukee are the best regular ones I have found. Last the longest and the tips are way more rugged than Sharpie IMO.
    05snopro440 likes this.
  6. Ziggster
    Ziggster
    Tried those as well. No luck for me.
  7. Ziggster
    Ziggster
    What do they use at auto recyclers? I’ve seen fine tip yellow marks on parts. Those seem to stay on. While soldering the copper coolant pipes on my speedster project, everything I tried came off. Was super frustrating as I needed the marks to align the parts. Ended up just scribing marks.
  8. K13
    K13
    I can't say I have seen anything at a junkyard I would call fine tipped. You go from saying sub zero and oily to needing them to stay on while soldering. Not exactly the same scenarios. You need a welders pencil if you are soldering.
  9. manyolcars
    manyolcars
    I use liquid paint in squeeze tubes from the arts and crafts part of walmart. I use yellow to mark parts. It can fade badly but leaves a 'welt' of thick paint that lasts for years
  10. Ziggster
    Ziggster
    Stuff rubbed off before soldering.
  11. K13
    K13
    Why are you rubbing it? Make the mark and leave it alone it shouldn't be that hard to avoid handling the marked area. Once the area is lined up the mark has done its job. Sounds like a lot of operator error not material issues.
  12. RodStRace
    RodStRace
    Heck I don't work in sub-zero temps! :D
    Sorry, can't offer a solution.
    57Fury440 likes this.
  13. HOTRODPRIMER
    HOTRODPRIMER
    Uni-Markers, the are enamel paint markers. HRP
    If that don't work a case pocket knife will probably do the job. :D HRP
    mad mikey likes this.
  14. Ziggster
    Ziggster
    Had to mark in-situ, remove, and then clamp in vice. Lots of handling. Expected the stuff to stay, but it didn’t. Copper pipes were clean /grease free. Used both the Sharpie and Milwakeee markers with the same results. This was in my ba*****t at 70F plus. Not sure why they both rubbed off.
  15. Matt Dudley
    Matt Dudley
    from New York
    I get permanent markers from Lowe’s. They sell them in like 30 packs for $15 or so. They don’t work for everything but good around the house and shop.
    paint markers are where it’s at if you want permanent. Craft stores sell them but also auto parts stores usually carry white and yellow
  16. Rickybop
    Rickybop
    Engraver maybe?
    seb fontana likes this.
  17. fuzzface
    fuzzface
  18. 05snopro440
    05snopro440
    A sharpie might work in sub-zero, a paint pen will not. As far as working on oily surfaces, good luck. If you need to align two pipes, a quick straight scribe line is your best bet.
  19. Doublepumper
    Doublepumper
    from OR-WA, USA
    Black and silver Sharpies work for me. Many times I'll use some tape on whatever I'm trying to mark, then mark that.
    mad mikey and 05snopro440 like this.
  20. Kevin Lee
    Kevin Lee
    Super Moderator
    Sounds like a fool's errand. The problem seems like it has less to do with what you already have available and a lot more to do with how you're utilizing it all
    I suggest:
    • tiny mark with a scribe
    • looking at witness marks and remembering their position
    • tacking in place and removing in a way you haven't considered
    • winging it (using the force)
  21. Oneball
    Oneball
    Rickybop, -Brent- and TrailerTrashToo like this.
  22. theamcguy
    theamcguy
  23. Paint pens. I gave up on markers as they fade in sunlight, and use paint pens. Lots of colours available and they wipe off with thinners.
  24. Ziggster
    Ziggster
    Some intetssting stuff I’ll have to check up on. I should have clarified “marker” to incl paint pens. Not up to what the correct terminology is for this kind of stuff. Have had mixed results with these. When working properly, they do leave a permanent mark on almost any surface from what I’ve found, but they either clog, emit liquid sporadically, or it gushes out. Good for some large marking/lettering, but not good for alignment marks. Being mostly lazy, when I do scribe “alignment” marks, it’s freehand (using the “force”) and rarely does the line end up being straight across both pieces, so some guesswork/memory involved. Never really ever thought of using a straight edge to scribe alignment marks. Maybe I should start…lol!
  25. Fortunateson
    Fortunateson
    When my paint sticks or welder markers dry up a tiny dab of Brake Cleaner usually gets them going again.
  26. "Grease Pens" work great. You can get em in black, white, silver. They write on just about anything!
