Technical best spark plug for ford flatheads
Discussion in 'The Hokey Ass Message Board' started by fordpatina, May 30, 2014.
  1. fordpatina
    fordpatina
    Hello like the title says what is the best spark plug for ford flatheads V8S to use any particular ones? thanks in advance
  2. 19Fordy
    19Fordy
    I think a lot has to do with what kind of heads you are running as the "reach" and "heat range" of the plugs vary. The folks on www.fordbarn.com are in the know. Champion H-10's used to be the stock plug for 49-53 flatty, but they are not made anymore.
  3. telecustom
    telecustom
    from Langey, BC
    Champion plugs are now made in Mexico. NGK has plugs for flatheads, and you can choose the heat range you want.
  4. i'm happy with ngk b-6L.....
  5. joeycarpunk
    joeycarpunk
    from MN,USA
    Best stock plugs I've used are Autolite 216's. My flathead runs better with these than with Champions.
  6. telecustom
    telecustom
    from Langey, BC
    Now with NGK five is norm, four is hotter and six colder. Four for that old dirty flatty losing comp. And six for that high compression motor. I think that's something to consider when running a flatty over 8.0-1 comp.
