Best Spotweld Cutters
Discussion in 'The Hokey Ass Message Board' started by 69supercj, Apr 26, 2010.
  1. 69supercj
    69supercj
    Getting ready to do a lot of spotweld cutting and I'd like some recommendations on what brand of spotweld cutter to buy. Gimme your suggestions guys!:)
  2. olddrags
    olddrags
    from ky
    I've used Blair for years, never had any problems.
  3. Master of None
    Master of None
    +1 for Blair, I recommend kit #11096 because it has the arbor plus an extra pilot ans 3 extra cutters.
  4. 1/4" bulletpoint drill bit, most cutters leave to big of a hole for my liking. If you carefully drill em out you can pop the panels free of each other.
  5. Brad54
    Brad54
    from Atl Ga
    I've found that if one of the panels is going to be destroyed/replaced, and the other is to be saved, then cut as much of the junk one away as possible to get better access to the seam, and then split the seam with a cold chisel and hammer. It's a lot faster than a spotweld cutter, and you have less dressing to do on the seam with a grinder when you're done.
    -Brad
  6. jpm49c
    jpm49c
    Blair cutter $20, Harbor Freight cutter $4.95. The Harbor Freight works just as good for me! I did break the pilot on the HF one and used the Blair holder with the HF cutter because the Blair cutter broke. John
  7. Streetwerkz
    Streetwerkz
    I have the Blair/Jancy style that I bought from Snap-on and love it.
    I'm not sure which of the 2 make them for Snap-on, but the kit werkz great
  8. brad2v
    brad2v
    I just recently bought a Blair, been drilling and/or cold chiselling for years beforehand. The Blair is my new favorite tool! (until the next one)
  9. papastoyss
    papastoyss
    I use a 1/4 " round carbide burr in a die grinder to grind out the weld & split the panels w/ air chisel.
  10. magnet
    magnet
  11. AAFD
    AAFD
    from US of A
    Blair for me.
  12. FormerFueler
    FormerFueler
    Another vote for Blair,Have had my set for years
  13. nutajunka
    nutajunka
    I just center punch and drill all the way through the spot weld with an 1/8 inch bit, and then measure the diameter of the spot weld and use a drill bit ground real shallow to take the top sheet off. That way when I weld I get to fill the 1/8 inch hole in the main metal and finish out the outer level. A little grinding, done and strong.
  14. sensor
    sensor
  15. knotheads
    knotheads
    i needed a spotweld cutter not long ago ,the paint store said the blair tool was back ordered so i used harbor tool cutters.i bought 2 cutters and have cut at least 100 spots with the first cutter,havent needed the second one yet. these cutters work pretty good for 4.95 each. i will most likely still get the blair rota broach tho.
  16. Blackie
    Blackie
    St used a Blair today and think it's awesome.
  17. flthd31
    flthd31
    Here's another way.
    I like this method when I want a hole to plug-weld the parts back together. It's fast and clean.
    I drill a hole in a small piece of 1/4 inch plywood for a pattern and use my plasma to burn the spotweld out.
    Here I'm plug-welding the new gutter I fabbed from the inside thru the holes made by the plasma.
    Might be of some help if you have plasma.
  18. Terraizer
    Terraizer
    Spitznagel(Dent Fix) spot weld drill.
  19. blt2go
    blt2go
    x2 on spitznagel. i used a snap-on model for a few years, but when i broke the centering pin they had discontinued that exact one so i couldn't get a replacement pin. got a spitznagel from a friend and haven't let him have it back yet. i also agree with brad54. i use a thick putty knife once i can get between the two panels and hammer it through the welds sideways. (i sharpen one side) good luck.
  20. traditionalrod
    traditionalrod
    from Canton SD
    I Like the RotoBroach Kit. I have yet to replace it and have had it 3 years. Plus if you buy the kit they also drill very nice round holes. I recommend looking around if you are going to buy one. My experience is that they are all made by the same company so find the cheapest tool company or your favorite dealer. Link to the matco variety.
    http://www.matcotools.com/Catalog/toolcatalog.jsp?cattype=T&cat=2485&select=&page=1
  21. bikersteve
    bikersteve
    The Blair is a handy tool to have around.......a step drill will work as well
  22. magnet
    magnet
  23. RUSTALOT
    RUSTALOT
    from GA.
    I picked up a couple at Harber frieght, wasent too sure about them but what tha hell they were cheap and they worked great.
  24. 6-71
    6-71
    I used Blair for years.I borrowed a spitznagel from a co-worker and it was great,but way too much money for me. I have used the H F cutters with great results.I think they were on sale for $2.95 ea. so I bought several. They last a long time if you dont abuse them.I also bent a pilot,and screwed the H F cutter on a blair pilot.
  25. budd
    budd
    oh thats good thinking, i'll have to give this a try, thanks
  26. UNSHINED 2
    UNSHINED 2
    Another + for the Blair. Use lube on the cutter and they last a long time.
    Have used center puches and drills in a pinch. With a panel splitter I made from a knife-edged dull file.
