Technical Best tiedown for car hauler
Discussion in 'The Hokey Ass Message Board' started by txcr13, Jul 27, 2017.
  1. txcr13
    txcr13
    Thanks to everyone. I got some real good education, so I don't have to learn some hard lessons on what to avoid.
  2. MrMike
    MrMike
    The two companies I have had the best luck with are - M&R Products, and AW Direct, not worth losing a life or a car over saving a few bucks, YMMV.
  3. Engine man
    Engine man
    from Wisconsin
    If you haul the same car on the trailer it's a good idea to make some cleats to get the vehicle in the same position each time. We tied the wheels down with 4 inch wide ratcheting straps over the tires and had blocks that fit under the frame in the front and rear then pulled the frame down so the vehicle didn't bounce on the trailer.
  4. mammyjammer
    mammyjammer
    from Area 51
  5. Four of these. Can be used around wheels, axles, etc.
    Your rating will be extreme overkill.
    And use nylon hose sleeving in the correct size. Cut into lengths as needed (2' or so) and slide over the nylon webbing to protect from cuts and abrasions.
    Your webbing will last for for years
    txcr13 and lothiandon1940 like this.
