Best tire size for my 64 F-100
Discussion in 'The Hokey Ass Message Board' started by lrs30, Jan 23, 2011.
  1. usa5913
    usa5913
    Has your truck been lowered? How much?
  2. mow too much
    mow too much
    I ran 235/75/15 on 15x7 and 15x8.5.
  3. usa5913
    usa5913
    What was the model numbers of you rims that you got from coker?
  4. A Rodder
    A Rodder
    I will check on the invoice, here is a pic with the caps finally painted and installed, Joe
  5. usa5913
    usa5913
    She is looking sweet!! My truck is lowered three in the front and four out back. I have problems getting the 235/75 on stock rims, out from the back. The tire hits the bed and the brake drum....pain in arse to get off. Any info on your rims would be cool. Thanks!
  6. lrs30
    lrs30
    from Kentucky
    Try jacking up the truck by the frame one side at a time.. This way it will let the rear drop/sag down enough to get the tire and rim off;)
  7. usa5913
    usa5913
    :eek: Good one... For some reason I was stuck on jacking the truck up by the axle. Thanks for sending me in the right direction.
  8. lrs30
    lrs30
    from Kentucky
    sometimes you just haveto step back and rethink the situation! Good luck with the truck!
  9. Mattilac
    Mattilac
    Yea its lowered about 4 or 5 inches all around.
  10. lrs30
    lrs30
    from Kentucky
    Mat I know I asked this before, but how did you lower yours? Was it mono leafs? or did you do a flip.. I'm still on the fence with the T-5 Swap, just trying to justify the cash to do it...lol
  11. Mattilac
    Mattilac
    Jag XJ6 IFS
    Front view
    Back view
  12. Mattilac
    Mattilac
    I also did the T5 swap behind the original 292. The truck cruises nice. I would definitely do it again.
  13. lrs30
    lrs30
    from Kentucky
    Did you buy a swap kit for the T-5 or did you do the mod yourself.. I like the JAG IFS idea, looks like bolt in kit?
  14. Mattilac
    Mattilac
    I got myself a WC T5 out of a Mustang and pretty much threw it in there. Actually, the way I did it isn't really a good method, but its held up okay. The bottom two bolt holes line right up, and I tapped out a hole into the bellhousing where a long bolt would reach from the driver's side top hole. So only three bolts are holding it in... and there is no tail crossmember... but it hasn't given me any problems at all, and I beat on it regularly.
    The Jag swap is awesome. I'm so happy I chose it over the other IFS options. It was not a bolt in kit however. But the crossmember EASILY adapts to our frame, so I fabbed some perches that make it cradle the frame rails, and then drilled holes to bolt it in. It's totally overbuilt- just the way I like it. I have a lot of information about this swap if you are thinking about it. Can offer all my measurements and notes too.
    If I ever get motivated to finish writing the tech article on the Jag swap, this is the first place I'll be posting it.
  15. JimV57
    JimV57
    I've got a 61 f-100 and I will be using 15x7's in the front with BF Goodrich radial TA's 225/60 15 and the rear will have 15x10's with the same tire except they will be 275/60 15. the rims are reversed with a backspacing of 2 1/4 in the front and 2 3/4 in the back
  16. lrs30
    lrs30
    from Kentucky
    Cool thansk for the info guys.. MAtt I will look it up.. If I can squeeze out some money from somewhere the T-5 Swap is a huge want!...
  17. LowA100
    LowA100
    What year/model Jag is it??
  18. LowA100
    LowA100
    Does your rear-end housing hit your bed floor??
  19. Mattilac
    Mattilac
    Came out of a 1982 Jaguar XJ6. It's easy to get as it just unbolts from the car. But then you need to make it fit your chassis.
  20. supervert
    supervert
    235/75-15 all around on mine
  21. lrs30
    lrs30
    from Kentucky
    I got my wheels and tires all painted, mounted and on the truck.. 235's on 15x7 in the front, and 275 70 15, on 15x8's in the rear> I am getting shit for painting them black but they look killer to me, and thats the only person I have to please...lol
  22. lrs30
    lrs30
    from Kentucky
    terrible cell phone pic, best I got for now
  23. jake8092
    jake8092
    Thread is a little dead...
    Little Red got new shoes!
    Thinking about diching the baby moons and going with some bullets :)
  24. shocker998md
    shocker998md
    I have 205/65/15s on some 6inch wides up front and 255/60/15 out back on 8s. Ill be playing with tire size more when I lower mine more.
  25. jake8092
    jake8092
    I went 275/60/15 in the back on 8's and 225/70/15's up front on 7's...Overall Im pretty happy with it them, axle flip in the rear and one of Sid's axles up front -2 leafs. I like the way it sits in the rear but the front still needs to drop another inch or so. I'm going to reverse the spring eyes this weekend and play with it a bit more!
  26. shocker998md
    shocker998md
    Need pics of that jake! I was worried about going to a 275 on an 8 inch wide wheel and flipping my axle.
    can we get pics of ur notch and stuff too?
  27. jake8092
    jake8092
    I'm working on the notch this weekend, they tires and wheels went on late last night so I'll keep ya posted as it progresses! Ive only had the truck for a few weeks and trying to make it my own...Ive got plenty of clearance with 8's on 4 inches of backspacing, they were a mother to mount but we were able to get it done! With the axle flipped I have zero to no clearance between the axle and the rear frame rails.
  28. shocker998md
    shocker998md
    yea I want to flip mine, step the tire up to the tallest that will fit and then eventually clip the front. What did you set ur pinion angle to? Definatly snag up some pics. For ur notch are you using DOM tubing or plates?
  29. fef100
    fef100
    That is some good stance. My '68 has 225/70/15 on 7s up front, 255/70 on 8s out back. Still have to sort final height when it is back together. I'm hoping for something similar.
  30. jake8092
    jake8092
    The blue truck ^^ does sit great but I just want to get as low as I can without having to but into the bed, I looked at a lot of trucks the past year and this was the more solid of the uni's Ive been able to find. It also had a 302/AOD combo which didnt hurt in the deciding factor...
    I'm going to plate it, I bent up a few pieces of 1/4" x 2" flat bar the other day that Im going to surgically install lol
