Best way to get it up - the driveway.
Discussion in 'The Hokey Ass Message Board' started by kursed56, Dec 26, 2012.
  1. SUHRsc
    SUHRsc
    long piece of heavy pipe.... thread a chain through it.... hook to the axle of the car your pushing... and something under the front of the car your pushing with... the chain should be not too much longer then the pipe...
    you can figure out how long the pipe has to be, relative to where you hook it up on the cars....
    then you just get someone to steer and use the brakes... and push them in without harming the vehicles...
  2. roughneck424
    roughneck424
    My .02
    For a one time deal - FlatBEd Rolloff truck like mentioned
    For a longer term multi - use.
    I would rent a core drill to drill a hole in the cement in the back off the garage.
    http://www.sunbeltrentals.com/equipment/equipment.aspx?itemid=0320730&catid=s520
    Then cement / anchor a 2" receiver hitch in the floor. ( Flush to the floor ) Then install this http://www.got-chrome.com/popup.aspx?src=images/product/large/3610_1_.jpg
    Then slip a winch on the receiver into that anchor and winch away.
    I would not trust just bolts to the floor to anchor winch.
    You could use this anchor point winch to pull a motor too. That or pull down all the rafters in the garage :)
  3. J scow
    J scow
    from Seattle
    If I'm not mistaken you can use standard chain and a Chevy truck.... they have been making chain straight and pushing Fords for years! ;)
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    Our last house had exactly the same driveway pitch you have and I found it was safer and easier to just pay a rollback guy $ 35 or $50 to come and move it up for me. If I had been trying to move it up by myself there was the risk of it coming loose and rolling down and right into my neighbors house.
    Sometimes you just have to bite the bullet and pay someone a little to do things the right way. Sure a lot cheaper than my homeowners insurance deductible and having my rates go up through a claim.
    Don
  5. Idaho/Dave
    Idaho/Dave
    from Idaho
    Neighbor with a big 4 wheeler,
  6. 1931modela
    1931modela
    from montana
    The horse..... do you see it?????? the one that is getting beat to death.......... look...... right in front of you............
  7. 56sedandelivery
    56sedandelivery
    My garage/shop is in the back yard, and has a gravel driveway up from the street, around the side of the house, and into the backyard; and of course there's a slight incline. Over the years I've had to use a come-a-long or a block-and-tackle, to pull vehicles up to the garage area, and doing it that way takes too long and involves too much work. Theres a chain and hook cemented 4 feet into the ground at the top of the incline. Now I have a 9,000 lb winch. The plan is to bolt it to a hand truck I have, along with a loop of chain to connect with the hook/chain in the ground. The winch is still in the box, but the hand truck has been marked and drilled. I also thought about bolting the winch to a stub to go into my trucks reciever hitch. The garage/shop/driveway were done in 1990, and I've had to pull something up at least 6 times now. I've also got an old logging ******-block to put to use to make for less strain on the winch. The incline I have to deal with is about 60 feet long. My body's too old and broken down to keep doing things the hard way. Butch/56sedandelivery.
  8. 01Dudley
    01Dudley
    AGREE! I can't believe this thread lasted 2 posts let alone 4 pages.
  9. yup, sink a concrete anchor and then you can always screw in the big eyebolt and use the floor and remove it when you dont need it, the anchor stays in the floor flush.
  10. 63 Avanti 3137
    63 Avanti 3137
    Yes it's recycled so many times it seems seasonal... rolling, pushing, pulling, friends and I read the whole thing:eek:
    JScow and 1931modela.... where is the tip jar? You made it all worth while!
  11. 40Standard
    40Standard
    from Indy
  12. black 62
    black 62
    from arkansas
    this would be another good place to use a fat girl
  13. Fenders
    Fenders
    Lesson here...
    Twenty years ago I was selling my house and looking for another, little bigger blah blah...
    I p***ed on any house shown to me that had a steep driveway for precisely this reason.
  14. 26 T Ford RPU
    26 T Ford RPU
    Still got a hill to climb either way !! :) JW
  15. Rusty O'Toole
    Rusty O'Toole
    1) Drill a hole in the back wall of the garage
    2) Thread a rope through the hole
    3) Drive around in the back yard
    4) Tie rope to back bumper
    5) Tie other end of rope to heap
    6) Drive away, towing heap up driveway.
    Not really.
  16. This needs to end.
    End it on a good note but end it please.
  17. styleline
    styleline
    from so-hol
    this one works everytime
  18. I have done this getting a 2,000 lb Generator into a small room. I hooked a pully to an anchor bolt in the room. Ran a rope from the generator through a pully hooked to the anchor bolt and then hooked the rope around the axle of my truck. As I backed up the generator moved forward . I could see every inch it was pulled until it was sitting in the room. To hell with a winch!
  19. A small block Chevy may have a hard time making it up that driveway. Go with Pontiac Torque and you won'y have a problem!! LOL!
  20. 59 brook
    59 brook
    i did this years ago when i first started working on my 59 chevy wagon drilled a holle in the slab for a 5/8" bolt . sunk the anchor and set it in the hole bought a grade 8 5/8" x 4" bolt with some good heavy washers . harbor freight or northern hydraulics sell winches that go over a tow hitch ball get the one that powers in and out . hook the bracket over the bolt hook up a 12v battery and with a tow strap you can pull the car in or back it out . if the winch strains too much get a ****** block and you will be able to pull it
  21. HamD
    HamD
    I haven't used one of these but know someone who has used it for a drive with some incline. It has low range. trailervalet.com
  22. Lone Star Mopar
    Lone Star Mopar
    Have the ol lady get get behind it and push with your daily while you pilot the derilect vehicle. Tell her go heavy on the throttle as you wanna pick up as much speed as quickly as possible. When she reaches about oh say 88 mph have her jam the brakes. At this point you take over, Now your gonna Dukes of Hazzard that mother****er over the curb and all the way up that mountain of a driveway right into the garage. To hell with paying some sum***** to do anything you can do yourself,thats just dumb...
  23. Brucekoukalaka
    Brucekoukalaka
    :DGot access to construction equipment?...:D
  24. need louvers ?
    need louvers ?
    I can't believe I bothered to read this whole thread, but I gotta say iwannaflattie's answer is one of the best ever!
  25. Boeing Bomber
    Boeing Bomber
    Move. That garage is not for you.
  26. pinkynoegg
    pinkynoegg
    first, buy some ice cream
    second, buy an ice cream truck siren
    third, play ice cream siren
    fourth, when children come tell them ice cream is on you when they get the car in the garage
    five, crack a cold one and start working on her
  27. NINE INCH
    NINE INCH
    I gotta say there are a ****pot of hillbilly ways to do this. I'm thinkin if this is gunna be tough on ya...., just wait till ya start building your car. Maybe it should just go to a shop. Just sayin.
  28. Edsel58a
    Edsel58a
    Well, first off, being a do-it-yourselfer, you should have considered working on your car when buying your house. Any work outside will be null and void if being straight and level is an issue.
    Call a good contractor and lower the house, and level the driveway.
    If not, your project could be across the street in no time.
    Rollback... simple
  29. k1w1rodder
    k1w1rodder
    :Dfive ****** pages:Dhave ya got the damn thing in the shed yet:confused::D
  30. edweird
    edweird
    go buy a winch and mount it at the back of your shop. you will need it alot. make it with a quick disconnect to use on a trailor, etc.
