Customs Best way to get paint off hubcaps???
Discussion in 'The Hokey Ass Message Board' started by Sprout, Apr 22, 2015.
  1. Sprout
    Sprout
    I have my 62 Cadillac hubcaps and would like to polish them out. What is the best way to get rid of the old paint as to not damage the metal?
  2. guthriesmith
    guthriesmith
    I have typically used chemical paint stripper for things like that. Or, I have also just used compound if there isn't much paint left.
  3. MAD 034
    MAD 034
    from Washington
    Lacquer thinner works also.
    Weezy1930 likes this.
  4. Squablow
    Squablow
    Brush some paint stripper on there and wipe it off with paper towels when it wrinkles up the old paint. Do it a couple times and avoid s****ing or using steel wool, that'll keep the metal underneath smooth for polishing.
  5. Weezy1930
    Weezy1930
    from OHIO
    Lacquer thinner X2
  6. 49ratfink
    49ratfink
    I would use the Jascos paint stripper in an aerosol can. I had a bunch of dash parts that were chrome and painted but the painted part was all scratched up so I sprayed that Jascos on there and the paint just wiped off.
  7. Gotgas
    Gotgas
    from DFW USA
    Oven cleaner can also take care of it. It is fairly aggressive though, so try some of the other suggestions first.
  8. Sprout
    Sprout
    thanks fellas
  9. Chucky
    Chucky
    I just tried this product for the first time and was happy with the results. I needed to remove the 3-4 layers of black paint on the lower portion of my model A grill shell. I was concerned that it might screw up the stainless, but it did not. I had to apply it several times, mostly because of the several layers. It bubbled up pretty quick and I just wiped it off each time with paper towels. 4YLE2_AS01.JPG
    Squablow likes this.
  10. Mike51Merc
    Mike51Merc
    I've found that old DOT 3 brake fluid removes paint really well, usually in places that I don't want it to. :eek:
    plumbid and Maverick Daddy like this.
  11. Paul
    Paul
    Editor
    After you get the paint off, lacquer thinner, paint remover whatever,
    Brighten the clean stainless with 000 steel wool
  12. Rusty O'Toole
    Rusty O'Toole
    Steel wool will scratch. Try br*** scrubbing pads from the dollar store or fine rubbing compound followed by Flitz, Autosol, or your favorite chrome polish.
  13. jazz1
    jazz1
    Lacquer thinner won't damage your metal although you may have to soak your hubcaps for a couple days for the old paint to let go. "Gun wash" is cheaper than lacquer thinner and is the same product.
  14. Sprout
    Sprout
