best way to remove old carpet padding from a floorpan?
Discussion in 'The Hokey Ass Message Board' started by easttown, Jul 20, 2013.
  1. easttown
    easttown
    I'm redoing carpet and have pulled up the old carpet and padding..the padding is the kind that has fibers that are glued to the floor...so there are still parts hanging on...what would remove it best? or do i have to sand it off?
  2. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    Anything that will neutralize the glue without removing any paint that might be on there should work. Might want to try in a small area the stuff called Goo be Gone ? I have had good luck with kerosene but use at your own risk
  3. cavman
    cavman
    Liberal amounts of WD-40 might do the trick. Then it might be WD-41
  4. 2racer
    2racer
    heat gun and gasket s****er
  5. mustang6147
    mustang6147
    from Kent, Ohio
    Gasoline and a match....
    No seriously, s****er, but depending how rotted and mouse piss soaked it is, you may wanna also consider a paper mask....
  6. 56premiere
    56premiere
    S****e it , wire brush . Do it dry because gooey glue is a real pain. And if you are going to glue new over it it wont sick to wd40 or other oily stuff. I use a razor blade s****er and a wood s****er. Jack
  7. stimpy
    stimpy
    heat gun and s****er , and 3m adhesive remover ( woodgrain remover ) it will take the glue off without removing the paint ( use it outside as the fumes are nasty )
  8. Special Ed
    Special Ed
