Best Wiper Mount Types and Why
Discussion in 'Off Topic Hot Rods & Customs' started by Dale Myers, Mar 4, 2025.
  1. Dale Myers
    Dale Myers
    I've got an '89 Jeep Comanche with the pin type blade mounts that came with it. One of my blade clips is messed up and I've seen critiques of the pin type mount (OEM style, I believe.) I've had J type mounts on vehicles and they seemed tighter.
    Should I stick with the pin mounts and get new blades or consider a different mount. I see there are many options. If you've had experience with a lot of types, which would you prefer or avoid.
    Thanks
    Dale Myers
  2. deathrowdave
    deathrowdave
    from NKy
    Some places do not care pin mount blades anymore . My old Power Wagon has this style mounting also . Must be a Mopar thing . I understand Ford Arms fit as replacement perfectly
  3. Dale Myers
    Dale Myers
    I think I'd rather not continue using this system if replacements are getting hard to find. And I've read the J hooks are most common. Do other types have anything to recommend them?
    Dale
