Hot Rods Better 4" or 4 1/8 flathead crank?
Discussion in 'The Hokey Ass Message Board' started by rodderbilly, Feb 14, 2021.
  1. rodderbilly
    rodderbilly
    from italy
    Hi all, so..after lot of visible problem is time to rebuild my 8ba..it has a 3x3/4 crank…..was thinking
    to buy at stroker kit and bore the engine ,with aluminum flywheel?? i have a potvin climax 400 lift cam,and navarro intake with 97s,isky spring with hollow adjustable lifters,what you suggest ? what stroke is better?i have a 3 speed for transmission and 48 banjo axle…i really like fast accelerations….thanks for your help...
  2. No subs***ute for cubic inches. Go big my friend you will not regret. Don’t be afraid of a 4 1/4 stroke. Will cost close to same as 4 or 4 1/8th. Enjoy.
    ottoman likes this.
  3. Model A Gomez
    Model A Gomez
    Well if the transmission survives you will probably break axles or shear keys, they aren't real strong and won't take a lot of abuse. I have to agree with KIWinUS that the cost is about the same so go with the 4 1/4' stroker kit.
    acme30 likes this.
  4. Bandit Billy
    Bandit Billy
    I went with a merc crank in mine. Aluminum fly wheel, overbore of .125 and a 471 blower. It runs better than a SBC but no match for a 455 Olds. It cost a ****** fortune to build. I have absolutely no regrets! :cool:
    Desoto291Hemi likes this.
  5. rodderbilly
    rodderbilly
    from italy
    The 4 1/4 stroke needs lot of engine modifies….i have to grind the lower part of cylinders cause the rods interference , going to buy a balanced **** kit 4 1/8 x 3 5/16 …will do a good porting job and shim correctly the valve springs for correct pressure in all of them….
