Projects Better late than never , 29 AV8 roadster build
Discussion in 'Traditional Hot Rods' started by Cody49Ford, Dec 27, 2016.
  1. Cody49Ford
    Cody49Ford
    Yeah that guy don't know what he's talking about , I'll give him $1500 California dollars for it
  2. Cody49Ford
    Cody49Ford
    The only roadster I had ever been in previously had wood floors and I dug it ! Decided to give it a shot and I'm super happy I went that route.
  3. tinkirk
    tinkirk
    Cody
    it does look nice just wondering what did you do for the seat?
    and what springs do you have under it? I put a posie reverse eye rear spring in mine and am not happy with the stance in the rear!
    going to start taking more leaves out and see what happens
    Tinkirk/Terry
  4. Flathead Dave
    Flathead Dave
    from So. Cal.
    I was going to do wood floors in my 27 Coupe. A lot of rodders do the wood floor. They do look good.
    Cody49Ford likes this.
  5. Cody49Ford
    Cody49Ford
    Yeah , they look good and play the part well . Definitely happy with them ! Thank you !
  6. mit311
    mit311
    I'm doing something very similar (putting a '37 21-stud in a '31 roadster) to what you did and wanted to talk firewalls. Did you have to recess yours at all or did the motor fit? I know guys with 24 studs have a VERY tight fit and most have to move or alter their breather tube to miss the firewall.
    My motor is off being worked on and I am trying to figure out if I can get away with using a stock firewall with a "stock" radiator in stock frame holes. I'm getting a Brookville body, so I can get a recessed firewall, but I'd like to avoid if possible. I'm also running a stock gas tank, so I'd run the stock mechanical fuel pump on the breather (if it fits).
  7. I can't see a 21 stud versus a 39-48 24-stud flathead making any difference as far as firewall clearance. Now when you get to the 49-53 engines with the different distributor setup . . . things can get a bit more difficult at the front of the motor, due to pulley locations, etc.. The manifold and breather tubes on 32 - 48 are in the same locations.
  8. 48fordnut
    48fordnut
    Any pics of the f1 clutch arm where it mounts to the frame instead of the throw out shaft?
    Thanks,
    jim
  9. Cody49Ford
    Cody49Ford
    I did have to modify the breather to get it to fit . Stock A radiator that was converted to work with a Flathead in the stock location , made a new breather plate and put a slight angle to the breather tube which gave me just enough room to fit a cap . It's all a real tight fit , but it works !
