Technical BEWARE!!! So-Cal Speed Shop 9" housings
Discussion in 'The Hokey Ass Message Board' started by M_S, May 9, 2016.
  1. M_S
    M_S
    from SoCal
    I would guess it would be similar to the coil over, with the leaves acting as a track link?
  2. gimpyshotrods
    gimpyshotrods
    What you see in that picture is a broken weld. Unless the manufacturer elected to use some horribly inferior filler material, this would be ER70S. The 70 in that designation is 70,000psi filler material. A quarter-inch wide bead around a 3" tube has at-minimum 2.3562-square inch contact area (***uming only surface attachment). That would be 164,934psi to fracture.
    Mild steel yields at ~43,000psi. If that were a sound weld, and the forces that you are describing would have bent the tubes and center-section well before breaking the weld.
    This is, plain and simple, a bad weld.
    Blues4U and loudbang like this.
  3. krylon32
    krylon32
    from Nebraska
    absolutely right
  4. Does Johns Industries sell housings only ....... or can one purchase center sections with gears, as well ?
  5. M_S
    M_S
    from SoCal
    Thanks, I didn't think a 2800# car with, maybe, 270hp would be the culprit.
  6. Motor City
    Motor City
    from Michigan
    You now know the price SoCal puts on their reputation, and it ain't the price of a 9in rear end housing! Pretty sad.
  7. roundvalley
    roundvalley
    I was getting ready to buy a set of '34 Ford headlights from them. ADIOS!
    prewarcars4me likes this.
  8. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    I just got me a John's housing and axle's......Top Notch, Great Service, and everything I had spec'ed out. Quick turn around, and price. After this thread= inspected very carefully, although I don't have x-ray vision. I would say honestly= If I break this thing, NOT that it fails, I have something wrong= too much HP, and I'm going to be throwing some at it. I usually refrain from recommendations, but- my *** is on the line here, and I feel secure with my purchase, and have to say this product is top of the line. Check you tube video's to see for yourself.... Any Q's- You can PM me.
  9. tfeverfred
    tfeverfred
    You know, maybe.....just maybe, it's time to just pull your pants up, buy a new pair of underwear on the way home and call it a ****ing lesson. Find someone else to give your money to and......well, move on. Sometimes there comes a day when you just have to say, "What tha ****." Move on.
    slack and oj like this.
  10. gimpyshotrods
    gimpyshotrods
    The whole deal. Every little thing. Get some!
    amadeus likes this.
  11. uncle buck
    uncle buck
    He already has a replacement in the works. Would that be the same as he already bought some new underwear?
  12. tfeverfred
    tfeverfred
    Yup.
  13. dirt t
    dirt t
    So Cal is on my DNDB list.
    pat59 likes this.
  14. M_S
    M_S
    from SoCal
    The housing is out, here are better pics..,
  15. X38
    X38
    Looks like the welder completely missed the target.:eek:
  16. M_S
    M_S
    from SoCal
    Everyone that has looked at it said they thought it was machine weld, not on target and too cold.
    Larry T likes this.
  17. X38
    X38
    Yes it looks like a machine weld, set up incorrectly. I guess no one was paying any attention.
  18. Roadsir
    Roadsir
    你疯了他妈的美国人说我像焊接Stevie Wonder的
    Use google translate if you need help!
  19. pat59
    pat59
    Looks like 95% of the weld is on the center section.
  20. gimpyshotrods
    gimpyshotrods
    More even.
    pat59 likes this.
  21. Da Tinman
    Da Tinman
    Wow, if that was a machine weld that far off center I wonder how many went thru like that before (if) the machine was reset.
    31Vicky with a hemi likes this.
  22. krylon32
    krylon32
    from Nebraska
    Just unboxed a Johns 9 inch housing and looked it over carefully. The tubes are welded on the inside as well as the outside machine weld.
  23. M_S
    M_S
    from SoCal
    That is the entire purpose of this thread. One poster on the first page said the same happened to someone he knows, I am sure there are more out there.
  24. thirtytwo
    thirtytwo
    So the question is who is the mfg. ?
    Been said not currie, not johns... 9" housings from china now?
  25. I need help but no time to figure out google translate.
    Can you s**** feed it ?
  26. RmK57
    RmK57
    How much does a bare housing cost from SoCal?
    I know locally I can buy a big bearing f-150 housing for less than a $100 and get it narrowed
    to any width I want for around $250-300. And that's from a pretty reputable race car fab shop.
  27. Wooster
    Wooster
    from Soso, MS
    About 3 weeks ago I paid 600 for a So-Cal shortened for a model a on 32 frame. It has their forged spring hanger, ladder bar and shock brackets on it.
  28. RmK57
    RmK57
    I guess with all the brackets, hangers and all it would pretty much be a wash on cost then.
  29. socalhotrodder
    socalhotrodder
    Hey guys, I am a 17 year employee of Currie Enterprises. SoCal Speed Shop has not used our housings in many years. They did at one time, but "less expensive" options came on the market and they went that direction. Ours are made here in southern California, USA. I would prefer not to go into any further detail because I don't want to say anything negative.
    The housing below I grabbed off of our welding shop rack just now and snapped a picture of in my studio for your reference. All housings manufactured by Currie (in at least the last 5-7 years) will have the welded-on badge and all Currie housings, back to at least the early 90's that I'm aware of, have the 5 or 6 digit order number stamped on the tube. Hot Rod Housing Weld.jpg
    Roadsir and arkiehotrods like this.
  30. arkiehotrods
    arkiehotrods
    The OP stated early on that it was not a Currie
