The front 6.70-15 tires need to be replaced on my Model A. I am running 7.60-15s on the rear. I would like to go with a smaller diameter tire on the front for a little more rake but since I have a Super Bell dropped axle would this not be a good idea? Thanks.
Measure the current axle height. Look up the overall height of the tire you want to use. Do a little math. It going from a 27 inch tall tire to a 25 inch tire, your axle will be one inch lower
I run 5.60-15 on a 4" dropped axle with reverse eye Posie spring, so far no clearance problems even if the tire runs flat, I did adjust my caster because of the rake tho and I still retain the original style wishbone unsplit , your setup may differ....
Thanks. Wasn’t thinking this through correctly. Should know better posting questions past my bed time. LOL!
