Bias Ply Tires
Discussion in 'Off Topic Hot Rods & Customs' started by shedhouselife, Jul 18, 2025.
  1. shedhouselife
    shedhouselife
    Hello, Gents. I purchased a car that was tubbed and features 375/60/15 Pro-Trac bias-ply tires. I've tried different air pressures. At around 55-60 MPH, the rear end wobbles and shakes the car. Any ideas of how I can solve the issue? The front has skinnies -- 165/85/15 radials. What is the proper tire combination? All radials? It's a street car set up like a drag car. 406 tunnel ram with heads. Thanks!
  2. Acres
    Acres
    from Sweden
    Not sure how it works bias/radial combo, ive only driven with one type at a time.
    But wobble and shake, to me its a balancing problem, check the rims, and how old are the tires, are they egg shaped after sitting too long? the questions are many
  3. squirrel
    have you watched the tires as they rotate, to see if the treads are concentric? or if they move in and out as the tires turn?
    I thought Pro Tracs were from Coker? who has a bad reputation lately for making out of round tires. I had a pair of Coker brand bias ply tires a few years ago that did that, I wound up taking them to California to get shaved, they were better after.
  4. shedhouselife
    shedhouselife
    I don't know how old the tires are but I ***ume several years old at least. Could be the balance.
    chryslerfan55 and Acres like this.
  5. shedhouselife
    shedhouselife
    It does seem to be that they are out of round, yes.
  6. guthriesmith
    guthriesmith
    I have driven lots of cars with radial skinnies and bias rear tires although not quite that wide with good luck other than some walking in the rear on roads with ruts worn in them. As mentioned, sounds like your tires are either not round or not in balance.
    SS327, Acres and shedhouselife like this.
  7. catdad49
    catdad49
    This is the last version of my old T bucket, big and littles, bias and radials. After correcting the ackerman, this thing rode pretty nicely. On the interstate at speed, around town, it didn't matter. Find a old school tire shop, maybe a truck shop, they may be able to help if they are out of round. Don't over inflate, had N50's (several sets) on my GTO, probably 20psi max. If all else fails a couple smoky burn outs might help! Oh, pics..,,,,show us what ya got!! IMG_0371.JPG
  8. Illustrious Hector
    Illustrious Hector
    Wow, that's a long way to go for a "shave"
    I was *****ing about having to go a hundred
    miles last time to do a set.
  9. squirrel
    I combined it with another trip...
  10. jimmy six
    jimmy six
    Probably came to Nate Jones..many Bonneville racers have used him for years. His shop is very close to the Long Beach airport. Signal Hill….
  11. squirrel
    you can tell by the oil derrick?
    jimmy six likes this.
