Bias Plys vs. Radials... Chime in folks!
Discussion in 'The Hokey Ass Message Board' started by Action Girl, Oct 23, 2003.
  1. DrJ
    DrJ
    [ QUOTE ]
    I run the bias plys on the roadster because it has no fenders and it needs the look......
    Clark
    [/ QUOTE ]
    Probably the ONLY good reason to run bias ply, The look!
  2. Action Girl
    Action Girl
    I love my 51, but I aint selling my 2002 New Beetle and relying on her to get me from point a to b in the same way that I reply on my beetle.
    If the 51 was going to be a daily driver I'd be doing a ton of things to get it ready for that. Things like a mustang front end, newer technology engine, etc.
    It's the same with my scoots. I've got a new state of the art but looks old scoot and an actual old scoot that will be suited for parades, rallies, non city driving, etc.
    So..
    I guess it all depends on what you are asking your car to do for you.
    Stacey
  3. Fat Hack
    Fat Hack
    from Detroit
    Oh yeah...forgot to add...Michigan roads are dangerous enough in a newer car with radials...those 6" ruts, curb-height pavement shifts and piss-poor seams would have you working overtime to keep a car with bias tires in one lane!
    (This is something I KNOW!! [​IMG])
    I used to get out of my bias-equipped rides feeling whipped....after see-sawing the wheel back and forth across town fighting the car every inch of the way...part of the "experience" of driving an older car that I can live without these days!
    In other states, I'm sure that bias tires wouldn't **** quite as bad...but here they're best left to the masochist!!!
  4. hudson_hawk
    hudson_hawk
    bias are cool and look great but i fought my car for 6 months before i switched and have only thought about going back for cost reasons. stick w/ radials, especially on BIG cars with lots of wieght, its so much easier to control w/ radials
  5. =mike=
    =mike=
    [ QUOTE ]
    [/ QUOTE ]
    I disagree . Unless you have power steering , radials **** on a heavy car . In a biasply , with the smaller footprint of my firestone biasply tires the car turns like it has power steering . I had a shoebox along time ago and it had radials , it turned like a dumptruck . the radials had a huge footprint and it felt like it was turning in a puddle of mud . of course with a smaller footprint you lose a little traction which could be a bummer if you like to corner in excess of 100 mph ( which I dont ) , but otherwise I would take B/P handling characteristics over radials , any day .
  6. Kevin Lee
    Kevin Lee
    Super Moderator
    Does anyone remember what message board this is? Hahahaha. With the excepiton of the odd fastener and a few patch panels here or there I can't readily think of a single piece on my entire car that is less than fifty years old. Radials? C'mon. Not on my car ever.
    But by all means knock yourself out if you think you need them - I'll never berate you for it.
  7. Gr8ballsofir
    Gr8ballsofir
    That's what I said, Grimlok. [​IMG]
  8. Elrod
    Elrod
    I will try to describe the difference with bias ply tires vs radial tires on your old car in a checklist type of fashion.
    Radials will be harder to turn the front wheell when standing still. Radials will drive straighter on roads that have groves, ruts and will not try to grab every line in the road. Radials will last longer. 30K - 50K miles on a set.
    Bias Ply tires are narrower and will turn easier at slow speeds than radials. Bias ply tires will squeal when you turn corners at 15-20 miles per hour. Sounds like a soft burn-out. Bias ply tires will try to grab grooves in the road and follow them, so you have to really drive with both hands on the wheel. Bias Plys will wear out faster. 15K - 25K miles on a set
    Now for the opinion part of my post. I think radials look wrong on an old car. They are too fat and the tread pattern is not right. I run bias ply tires on all my old cars, because a bias ply white wall looks WAY better than a Radial White wall. Also, those radial white wall tires they make now turn yellow for some reason. EVERYONE will tell you not to buy the Coker Radial White walls, and they are pretty much your only option in white walls when it comes to radials.
    Now, you decide.
  9. DrJ
    DrJ
    Just for the record, I agree, WWWs don't look right on a radial unless it's an old Continental radial WWW on an old VW.
    IF I ran WWWs on a car they would be bias ply, but I'd have to have a big trunk o store the alternate four "real" highway tires in!
  10. Mel
    Mel
    Right now I'm running the Walmart special... uniroyals at $25 a tire because I'm broke. Althought bias plys don't handle as nice as radials, some wide white bias plys would be nice someday since my rims don't take kindly to the tubeless radials (always leaking [​IMG] ) and IMO bias ply's look better.
    ~Melissa
  11. Kojack
    Kojack
    I... really couldn't tell too much of a difference between the radials on my '64 Galaxie and bias-plys. I think some one said something about the biasplys handle better with heavier cars... I'd have to agree with that then, as the radial's seemed the same or even more squirrelly when I hit bumps with my wal-mart radials then when it did with the old bias.
  12. young buck
    young buck
    dr j have you ever checked out diamondback tires...they made my friend a pair of radial www and look sweet...we drove the car 8000 miles this summer with no problem
    diamondback sent the tires from england (16 inch) and then valcanize their white wall on that tire...at the end there is no lettering on the outside of the tire for a real clean look
    young buck
  13. crclebrner
    crclebrner
    Ok, I'm chiming in as someone old enough to have driven daily and competed on both radials and bias ply tires. As a matter of fact, we are still competing on bias ply tires. the IMCA spec tire is bias ply and you have to completely adjust your driving style on them compared to running radials but, we are talking traditional rods and customs here. I have to agree with the old school thinking that modern radial tires look out of place on a rod and there are some advantages to the bias ply tires. For one, bias ply tires don't seem to come apart as destructively as radials do. Radials will definetley hairlip the corners of your fender wells when the steel belts separate. 2: You can run the bias ply tires until they have almost no tread left where as it is little known that radial tires are effectivly worn out when 50% of the tread is gone and are subject to separation and just don't perform as well after that. With some cheaper radials, it is even sooner. 3: Although radials are vastly superior in almost every respect when it comes to handling, the do have a much more sudden breakaway factor than bias ply which could get a novice driver attempting to drive to the limits of the tires adhesion into some ugly trouble. For me, I will stay with radials on my 57 Ford because they don't look that bad and the car drives great with them but, if I actually get around to building my 46 Merc, I will probably try to get period correct tires.
  14. krupanut
    krupanut
    I run bias plies on both the roadster and my 51 Chevy.
    I have no complaints about them on either car.
    The roadster is light and no problem to maneuver on rutted high ways.
    The Chevy had radials on it when I bought it. The front end was really squirrelly with them. I found some nos cushion air bias plies, $50 for the four of them. The car rides great with them. I agree with what Mike said, the suspension is set up for the old technology so it works well.
    Plus I’m a total cheap skate and bias tires are cheaper.
  15. do you want your car to look like its from california, or florida. thats what it all boils down to.
  16. Fat Hack
    Fat Hack
    from Detroit
    Ha Ha!!! Way to go Ricky! [​IMG]
    California = Bias
    Florida = Radials
    Michigan = Swampers
    [​IMG] [​IMG] [​IMG]
  17. nummnut
    nummnut
    i love my b-p's and i drive the **** out of the hi-1
  18. continentaljohn
    continentaljohn
    Ok Fat hack, so are your swampers are Bias ? If she big and a old set it is [​IMG]
  19. MercMan1951
    MercMan1951
    I really didn't want to get in the middle of all this, but all I want to say is that I have fond story that goes along with bias plys..
    It's 1985. I'm 10 (DON'T BOTHER ON RIPPING ON ME YOU OLD GUYS...)
    This guy around the block from me had a cherry 1969 Caddy Coupe Deville (the 2 door).
    One day I ride over there on my dirt bike to see what's up (I did this alot, and credit him for getting me into old cars, paint and body work.)
    He's taking his radials off the rear, and bolting on some Sears bias plys that were older than me. Blackwalls, no hubcaps...he just smirks and says he's trying out some old tires.
    That night, about 11 PM, I'm in my room (sing: "In my room....in my room...") with the lights out & in bed. I hear his car (I knew it's sound) drive by. i got up to see those tall thin Caddy taillights come to rest at the end of my street, a corner. All of a sudden he tears around the corner leaving the longest, loudest, squealing, smoky burnout I'd ever heard to that point. I could smell the rubber for 10 minutes in my bedroom. I heard a few more over the couse of the next few minutes. I got excited.
    Next morning, I rushed thru breakfast to grab my bike and inspect the pavement. Standing start, one wheel peel, around the corner and down the side street for at least 200 feet! Whoa.
    I peddal over to his place, and he's in his driveway changing out the back tires and putting on the "stock" radials and hubcaps. I didn't need to ask him what he had been up to the night before, and he knew I knew. When you're 10, things like that are pretty cool.
    That, and having a guy who's 20 let you hang out while he works on cars. Not minding you're pestering him with questions. This one's for you, Rob...
    Bias plys do killer burnouts, and as far as I'm concerned, that's about it. They look great on "museum cars"... [​IMG]
  20. hillbillyhellcat
    hillbillyhellcat
    Avoid putting them on a newer car at all costs.... Got a set of brand new bias snows dirt cheap and put them on my winter ride. They were 6.00X12 Good Year Silvertown Trail Makers, what they were originally intended for I don't know. The next day I took it on a 2 hour trip at speeds of 70 MPH. All I can say was that it was some serious white knuckle driving for a 20 year old kid. They hummed like Thornbird TSL Super Swampers and pulled at every single little crack in the road. They had a ton of rolling resistance so they got literally hot on the pavement. They ****ed in the snow. And they were bald in 4000 miles.
    I will have to admit, however - the car really did steer easy with em and they were *****in looking. This time I spent $20 extra and got radials. [​IMG]
  21. DeS
    DeS
    from Finland
    Bias Plys of course, those have more rock'n'roll than all records of Gene Vincent and GV is the KING
  22. zonkola
    zonkola
    from NorCal
    Bias plys have 'the look' for sure, but you can get in the general, fuzzy, looks-OK-at-60-mph-if-you-blur-your-eyes ballpark with a set of radials if you get the right sizes. C9's '31 roadster is a good example of this.
    Someone asked for a photo--my '32 RPU ch***is is set up with 215/85R16's in the rear and 165/R15's in the front, which I think is a reasonable setup if you're dead set on radials:
    Of course, I'm also putting flat black front disc brakes on a highboy, so I'm clearly out of my friggin' mind!
  23. Hey Zonk....where'd u score those rear radials in CA?
    Id love to get my hands on a set for my ride. Whats other sizes do they come in?
    Rat
  24. SKR8PN
    SKR8PN
    Bias ply's ****....
    When I FIRST joined this board,I made mention of this fact.....
    Ryan thought I was in the wrong place......
    I stand by that statement.
    They ****, if you want to DRIVE your car..........
    If you want it to LOOK pretty,then by all means,put a set of 'ply's on it............
    Ya ever lose a tread at high speed with a 'ply?
    OR....try to hold it in the 'groove' at speed with a set of 'ply's ????
    From a guy who has "been there,done that".......
    Bias ply's ****.
    And.......I will PROLLY put a set on my next rodney.....
    Go figure..........
  25. zonkola
    zonkola
    from NorCal
    [ QUOTE ]
    Rat
    [/ QUOTE ]
    The 215/85R16's are Dunlop Radial Rover AT light truck tires. That size is a bit hard to find stateside, but I found quite a few Japanese manufacturers that sell that size in Asia & Europe, but do not import it to the U.S. Not enough demand for them, I guess. Do a Google search on the tire size and you'll likely find them.
    The Dunlop tread is closer in vibe to old dirt track tires than old bias ply Firestones, but there you go. Some of the Japanese 215's I found had light truck 'highway tread' designs, which are the closest aesthetic match to a bias-ply tire I've seen in a radial. They don't import those here, but you might be able to get 'em...
  26. RawDeal
    RawDeal
    from Austria
    Why I have bias plys?
    ...because in Austria I pay $740,- for a set one bias plys and about $1200,- for a set of radials by coker...
  27. Revhead
    Revhead
    from Dallas, TX
    [ QUOTE ]
    I'm probably going to drive some distances but with no disk brakes, I think I'll be keeping my speed down till I get a handle on driving the m***ive beast.
    [/ QUOTE ]
    '51 chevy ... m***ive beast?? damn and I thought they were on the smaller end of the spectrum. I guess driving a '56 caddy for a while will do that to ya.
    For what it is worth my brother drove his ride around for like 2 years on bias-ply. Only in town though and not over 55. I never heard him complain about them.
  28. Thanx for the info Zonk....i'll scope it out here in Oz.
    Rat [​IMG]
  29. hotrodladycrusr
    hotrodladycrusr
    So Stacey.... did you order your "upgraded" radials yet??? [​IMG] [​IMG]
  30. Action Girl
    Action Girl
    The biggest car I've ever owned was Honda Civic. My current car is a new bettle. So, when you put them side by side, it feels like a beast to me [​IMG] (though I love her just the same!)
    Stacey
