Technical BIG 97 Stromberg help
Discussion in 'Traditional Hot Rods' started by Larry Kirwan, Feb 5, 2025.
  1. Larry Kirwan
    Larry Kirwan
    Thanks for post, I can't use a A/F meter, I'll try some of your thoughts in morning, will report back.
  2. Larry Kirwan
    Larry Kirwan
    100% what it was, with all 3 having idle circuits it was dumping to much fuel at idle, closed the secondary A/F screws and seems to run (idle) great, Thanks so much.
    1biggun, 2devilles and 51 mercules like this.
  3. Larry Kirwan
    Larry Kirwan
    OK guy's think I have it fixed, was a little high on fuel pressure, and closed the idle circuit on the secondary's-was dumping to much fuel in at idle with all 3 idle circuits, seems to be running real good now, THANKS for all responses... 100_0761.JPG
  4. 2devilles
    2devilles
    Fantastic news, glad that worked. And that is one beautiful mill you have there.
    Larry Kirwan likes this.
  5. Bandit Billy
    Bandit Billy
    Gald, you got it handled. Never give up, never surrender. Now, about that upper radiator hose...:cool:
    jebbesen and Tow Truck Tom like this.
  6. Larry Kirwan
    Larry Kirwan
    Thanks Brother.
    Tow Truck Tom and 2devilles like this.
  7. Larry Kirwan
    Larry Kirwan
    come on Billy, I built this for me-let's not get picky at this time....
    Tow Truck Tom and Bandit Billy like this.
  8. Larry Kirwan
    Larry Kirwan
    Guy's I want to say George Rooks at Summit was very helpful, and I needed it, mostly since I've gotten NO response from E-Mail to England or Max here on site-been 3 day's with NO response, I can't let myself think that's good service, but what the heck these carbs are only $1800. with manifold, fuel rail, linkage $2600.
  9. Bandit Billy
    Bandit Billy
    A fine answer and welcome to the HAMB.
  10. PotvinV8
    PotvinV8
    What are the O2 sensors for then?
    Going by what you're reporting, it sounds like you're close. Have you balanced the three carbs with a Uni-Syn? This is absolutely necessary to get those carbs to all pull the same vacuum. Also, I don't think you want to close the secondary carb's a/f screws. Setup the center (primary) carb and then adjust the other two to match, sync, and go from there. You're more than likely to find that the idle screws on the secondaries need to be opened up a touch while the primary needs to closed slightly to get them all to sync. Those secondaries need the a/f screws to be adjusted as such so that they pull in a tiny bit of fuel as the ****erflies are opened, otherwise, they're just a vacuum leak that the primary carb (and you) will fight to get tuned properly.
  11. 19Eddy30
    19Eddy30
    from VA
    Uni Syn or equivalent definitely needed and required when setting 2 or more carburetors,
    My self have 4 & all been calibrated so they read the same, makes adjustment easier
