Hot Rods Big and littles
Discussion in 'The Hokey Ass Message Board' started by jjjmm56, Jul 29, 2022.
  1. jjjmm56
    jjjmm56
    from FL.
    I'm getting ready to start a 27 roadster build and am wanting to run big/littles. What is the common tire and wheel size? Do you guys run a 15" rear with 14" front wheel? Pics if you have them please.
  2. indyjps
    indyjps
    Big and Little Height and Width, or same width?
    Got a pic of of car you like the stance?
    This
    OR
    This
    WC145, chryslerfan55 and Stogy like this.
  3. gimpyshotrods
    gimpyshotrods
    What era of are you looking to target for looks?
    1940 can look substantially different from 1950, and 1950 can look different from 1960.
  4. 34Phil
    34Phil
    I would stick to 15" wheels. Do you want bias ply or radials?
    chryslerfan55 and olscrounger like this.
  5. gimpyshotrods
    gimpyshotrods
    Depending on the era, region, and the build budget of the era/builder, they could have been 16-inch wheels, and even Wide-5 wheels.
    It all was done, and there is plenty of proof of that.
  6. 51 mercules
    51 mercules
    On my 29 Roadster I have 16x5.00 Firestone in front and 16x7.50 Firestone in the back. They are bias ply.[​IMG]
  7. HOTRODPRIMER
    HOTRODPRIMER
    Big L78-15 & little 5:50 -15 bias ply, 15", 5" on front & 7" on the rear. HRP
  8. jjjmm56
    jjjmm56
    from FL.
    The one with the wide tires is the one I’ll be changing
  9. jjjmm56
    jjjmm56
    from FL.
    I ‘m thinking radial
  10. gimpyshotrods
    gimpyshotrods
    8.90-16 rear. I think 5.50-16 front, but I cannot seem to find my other pictures of this car.
  11. alchemy
    alchemy
    As said, the era of hot rod style you are trying to build will dictate what looks right. Nothing worse than mixing your metaphors.
    Don't put 1948 steelies on a roadster with a SBC. But don't put Keystone Kl***ics on a roadster with a flathead.
    And don't put low profile radials on any roadster. Save those for a Camaro.
    WC145, catdad49, jimgoetz and 4 others like this.
  12. 34Phil
    34Phil
    165/80 (25.4" high) and 235/75 (28.9"), but the rears will be a long way outside the body.
  13. alfin32
    alfin32
    from Essex, Ma.
  14. gimpyshotrods
    gimpyshotrods
    If this is the car you will be swapping wheels and tires on, you may indeed have an axle issue.
    When you have a free moment, take a picture from the same position, with the left rear wheel removed, and then another showing the gap between the body and brake ***embly.
  15. Primered Forever
    Primered Forever
    from Joplin,MO
    WC145, charleyw, catdad49 and 2 others like this.
  16. jjjmm56
    jjjmm56
    from FL.
  17. gimpyshotrods
    gimpyshotrods
    Camaro covers a whole lot of years, and a whole lot of widths in a 10-bolt axle.
    Depending on the year of the donor, that could be somewhere between a tick over 60-inches wide, all the way to just over 65-inches.
    In any case, for a Model T, a typical well-fit axle width is about 58-inches.
  18. silent rick
    silent rick
    7.50-16 rear tires, go with 6.00-16 on the front unless you're running fenders, then go with a 5.50-16 on the front.
  19. jjjmm56
    jjjmm56
    from FL.
    Axle is from a 67. 60"end to end.
    Stogy likes this.
  20. JWL115C
    JWL115C
    Diamondback Auburn Tubeless Radials - 7.50x16 rears - 5.60x15 fronts.
    X38 and Stogy like this.
  21. jjjmm56
    jjjmm56
    from FL.
    Thanks everyone. This way I can get tire diameter.
  22. swade41
    swade41
    from Buffalo,NY
    I wouldn't get 14's, it's getting hard to find tires in that size.
    I run 5.60x15 up front and L78x15 on rear
    WC145 and chryslerfan55 like this.
  23. Stan Back
    Stan Back
    It always looks best, that, if possible, to use tires with the same or similar tread pattern (and/or the same profile whether taller or shorter).
  24. catdad49
    catdad49
    Fall A.jpg 5.60-15 on 5"rim and 7.50-16 on 7"rim bias ply.
  25. jimgoetz
    jimgoetz
    My take on what I would have built in the early 60s. 8.20 and 5.60 on 15 bias ply. DSCN1335 (5).JPG But I probably would have had painted wheels with screwed on Moon discs.
    WC145, '28phonebooth and catdad49 like this.
  26. jimmy six
    jimmy six
    This 27 on 32 rails has 16” stock Ford rims and Excelsior tires. 750 (31+”) on the rear and 500 (25”) on the front. Made by Coker but bought thru Summit, no shipping. Rear is lower than normal and has a QC. Sorry no side view and it’s in San Diego. D25C781F-B955-4C1D-8AEC-F46CD34EC12E.jpeg
    WC145, jimgoetz and catdad49 like this.
  27. primed34
    primed34
    I'd take a look at 16"s. 14"s and 15"s are getting harder to find. If you run radials, you may have a hard time finding tires that aren't already over a year old in the 14" and 15" size.
