Technical Big block caddy in a 52 mainline
Discussion in 'Traditional Customs' started by insinna, Aug 2, 2017.
  1. insinna
    insinna
    Trying to find an oil pan seems to be a challenge...as far as lifters go, I took valve covers off and rotated the crank and found #7 intake valve barley moves and push rod is loose... hopefully it is just a lifter
    Sent from my Z987 using The H.A.M.B. mobile app
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    One of the guys in our Ford Group here has done the Caddy swap and posted a lot of pictures in detail in a '53 Ford. Join the Group here: https://www.jalopyjournal.com/forum/social-forums/1952-59-ford-social-group.282/ You can contact that member here: https://www.jalopyjournal.com/forum/conversations/add?to=G***er1
  3. coupe33
    coupe33
    If you need a rear sump expect to pay $400 plus the pick up tube . Cheap advice just take a mid sump and have it modified you can get a new pick up $120 to $145. I have a rebuilt 472 that I was going to put into my 54 Pontiac and may still do it. Exhaust headers are available on EBAY average is $125 for stainless tight hugging center dumps.
  4. insinna
    insinna
    Where can I get a new one? Looked at Napa...no good....what year , model and engine should I be asking for?
  5. morac41
    morac41
    Try here ....cad500parts.com
  6. morac41
    morac41
    Try here......cad500parts.com
  7. JeffB2
    JeffB2
    from Phoenix,AZ
  8. insinna
    insinna
  9. coupe33
    coupe33
    Cad500 has a oil pan for $435 + shipping as I said they are not cheap.
  10. coupe33
    coupe33
    Ok don't panic. I have some things to do this morning and I will look in my pile of Cad parts. There is a book on Cad engines and I will see if I can find the specs for you. The block started in 68 and ended in 76 for the 472"/500". I am not sure about pans for the 425" 77/79
  11. JeffB2
    JeffB2
    from Phoenix,AZ
  12. coupe33
    coupe33
    Well I looked in my pile of left overs. I have a rebuilt stock carb for my 1972 472 never mounted went with a Edelbrock before the carb came back. A couple sets of valve covers stock and chrome. So I can't help.
  13. Jibs
    Jibs
    I have a 472 Caddy in my 47 Chevrolet sedan, had to notch the firewall for left head clearance, about a half inch. Try 500cid.com for Cadillac parts also. A mid sump oil pan might fit as is, that one on ebay might be a good deal.
  14. Gman0046
    Gman0046
    Back in the day, a friend of mine put a Cadillac OHV V8 ( don't remember the exact year probably a 365 or 390) in his 49 Ford and needed a dropped tie rod to clear the oil pan. A dropped tie rod was something you always looked for when street racing those 49 - 53 Fords. It was a dead giveaway you weren't going up against a flathead.
    Gary
  15. insinna
    insinna
  16. insinna
    insinna
    I'd like to think that there would be more than that to give away it wasn't a Flathead!
  17. JeffB2
    JeffB2
    from Phoenix,AZ
  18. insinna
    insinna
    I believe Hurst actually made them, only seen one, don't really need to do .... I had a sbc in the car before this and had about a half inch of clearance between the pan and center link....
  19. Gman0046
    Gman0046
    insinna, if you can figure out how to see through a closed hood to determine whats underneath it I'd like to know it.
    Thats the thanks I get for trying to help a newbie with 68 posts, a wise *** answer. If you know so much, why can't you figure it out yourself?
    Gary
  20. insinna
    insinna
    What I was getting at was the sound alone would be a dead give way....or can't you tell the difference between a Harley and a honda when they drive by...And who said that I couldn't figure out how to put an engine in any car....are you ***uming that I can't because I asked for advice, if anyone else has done it?...... Or because I don't post everything I do or think online.... check my resume pal ... I put out fires and turn dog **** into diamonds everyday
