Big block chevy in a 64 ford galaxie!!
Discussion in 'The Hokey Ass Message Board' started by old soul, Oct 14, 2013.
  1. speedyb
    speedyb
    from socal
    Grab an old Moroso BB/ Chevy II pan It I,ll slip in there great, I have Fords and Chevys, mix em up a little,pisses people off !
  2. 1971BB427
    1971BB427
    from Oregon
    If you're running drums all around (like I am) you wont use a proportioning block. I have front brakes plumbed to rear reservoir, and back to front reservoir. No prop valve.
  3. 1971BB427
    1971BB427
    from Oregon
    It certainly does! Can't tell you how many times a diehard Ford fan comes running up to see my Falcon, and then realizes it's not a BBF engine! Almost feel sorry for some of them; they look so sad. The 427 emblems on the side of my tilt frontend don't help, as they see those and think my 464 BBC is a 427 FE engine until I open the front.
  4. Davyj
    Davyj
    If you don't want to do all that fab work on the Z linkage, look at an 80,s S10 pick up, they had a neat little hydraulic clutch set up... should bolt right on that big block.
  5. mgtstumpy
    mgtstumpy
    A friend years ago put a BBC in an early Falcon after he took out the SBF. Tight squeeze but you won't have that problem, only the oil pan and mounts are an issue along with exhaust.:D
  6. Truckedup
    Truckedup
    I can't believe the FE guys haven't seen this thread...They would have a ****ing fit :D
  7. So did full size Chevy trucks. Easy to find. Maybe adapt a Wilwood clutch master cylinder to the Ford pedal ?
  8. old soul
    old soul
    from oswego NY
    any other ideas guys?
  9. junkyardjeff
    junkyardjeff
    I know for sure that my 37 Chevy p/u is getting a Ford motor next spring,tired of that slug of a 235 and want to make the Chevy guys cry. Any Ford motor would be better than that slow stovebolt that is in it now.
  10. old soul
    old soul
    from oswego NY
    That's fine jeff. I think it would be cool.
  11. old soul
    old soul
    from oswego NY
    What gear ratio do you guys think was in my galaxie? It came with a 289 3 speed crusomatic. Do you think the gears in it will be ok with the big block 4 speed?
  12. well this ought to be good !!!!
  13. junkyardjeff
    junkyardjeff
    Its going to be a 351-C that I have in stock,if I cant find a rear sump pan then its going to be a 272 Y block.
  14. Best I've seen was a 500 Cad in a Saturn, both GM, but Oh Boy did that Saturn get ****d to make it fit.
  15. Cerberus
    Cerberus
    Go for it! Your post and avatar for some reason reminded me of a root beer brown '55 Chevy 210 two door that had a 392 Hemi in it. It was For Sale at the Turlock swap meet car corral a few years ago.
  16. old soul
    old soul
    from oswego NY
    Wasent my 55. Its been in my neck of the woods its whole life.
  17. old soul
    old soul
    from oswego NY
    I found another 302 for 100 bucks. with cal custom valve covers on it. I really didn't want to put a chevy in my car. Ill try this one last ford motor, Wish me luck. And guys thank you for all the info.
  18. DeepRoots
    DeepRoots
    Old Soul. most 63 Galaxies I've seen came with 3.25 rear gears. Obviously you'd need to check.
    What I think is funniest about this thread is the 7-8 guys that remarked about some purist to come and **** this thread. It never happened. Use whatever engine you've got handy or can get cheaply.
    289/302's are ok in a Galaxie, but it's a heavy car (4200lbs +), torque is king. Fe's have their appeal, they look and sound very awesome and unique. A 390 can be built to be a very nice cruiser fairly easily.
    I've got a 429 in mine. I've had a few thumb their nose at me over it, but whatever.... It was the cheapest way for me to get the power I wanted. Trust me, if I could have afforded a 427 engine, there would be one in my car.
    I'm woefully ignorant about Chevy engines, but I doubt fitting it in there would be a problem, there is a ton of room in the engine bay. The issues you will have were already mentioned with one exception. The 63 Galaxie engine bay is very wide, but hood clearance is an issue. Unless you are willing to go with a teardrop hood your intake choices may be limited.
    for size sake, my 429 in my 63.5 Galaxie:
  19. So what's the exact trouble you are having with the ford engines ?
  20. 56don
    56don
    No one else came out to "****" this thread so I will. None of my business but its the HAMB thing to do to complain about some else's choice. So here goes:
    This is like putting a 460 Ford in a 57 Chevy Bel Air.
    There, now the Chevy purists have their complainant.
  21. Topless Ford
    Topless Ford
    Someone on the hamb had a 63 or 64 galaxie with a BBC. He ended up getting in a wreck (front end damage) and I saw a pic of it that way. If I can think of the user name I'll post it in here. Check the galaxie user group too.
  22. Zerk
    Zerk
    Thank you for your selfless act of reproach. You have upheld the HAMB reputation as a bunch of cantankerous old wishbones.;):)
  23. 56don
    56don
    Hey, somebody's got to do it when duty calls...:rolleyes:
  24. old soul
    old soul
    from oswego NY
    If that's what you want to do to your car. Go ahead wouldent hurt that bad. Its hot rodding.
  25. old soul
    old soul
    from oswego NY
    The issue I was having. Is I had my 302 rebuilt and I could not get the intake to seal. I was mad cuz I had the intake on and off 5 times. The heads must have been resurfaced more then I thought. I know I have to take the motor to have a intake milled for it. Im pissed because its my first ford and im a chevy guy. I wanted to keep the car all ford because I didnt want to take the easy way out and jam a chevy in it when I bought it as a roller. I spent a lot of time hunting down a motor and ****** and having it rebuilt. I was mad so I was gonna jam a chevy in it. For now I picked up a little sbf to jam in the car. Im actually having trouble decoding this new motor I picked up. So far I think its a 289 block with 302 heads and a 80s flywheel on it. Any ford guys out there??????
  26. tfeverfred
    tfeverfred
  27. old soul
    old soul
    from oswego NY
    Thanks for the info. And your motor looks great by the way.
  28. So it's not just fords , it may be the this particular lump's individual pieces.
  29. old soul
    old soul
    from oswego NY
    yea pretty much I geuss
  30. If it's the intake end seals that are driving you crazy, throw them away.... Put a nice fat bead of silicone at each end, let it partially cure up, then install the intake and let it cure over night. I use a couple of pieces of 5/16" threaded rod screwed into a couple of the manifold bolt holes as a 'guide' while dropping the intake on.
    The other thing to check is which heads you have; if somebody has installed 351 heads, you need 351 intake gaskets.
