Technical BIG BLOCK CHEVY STARTER - GOOD 1's? BAD 1's?
Discussion in 'The Hokey Ass Message Board' started by Clik, Jun 23, 2020.
  1. Clik
    Clik
    I was getting ready to order a mini starter and a buddy of mine said there was a recent run of defects but he couldn't remember which brand. Anyone have any input?
  2. squirrel
    I did ok with a stock replacement starter for a 1999 3500 pickup. It requires special bolts. The bonus is that you can find a replacement at parts stores, unlike the mini starters.
    And the stock 99 starter is a mini starter...but it's designed well.
  3. wheeltramp brian
    wheeltramp brian
    Same as squirrel,they work great
  4. saltflats
    saltflats
    from Missouri
  5. Clik
    Clik
    The numbers on the block looks like it was made in 1972. #3999289 K 72 GM 9 T
  6. Ericnova72
    Ericnova72
    from Michigan
    Retro-fitting the modern PMGR(Permanent Magnet Gear Reduction) style factory mini starter, like the DB Electrical link and Squirrel mentioned, is the hot ticket. Basically all you need to know is which flywheel/flexplate diameter you have, 14" or 12-3/4", , so the starter will have the correct nose offset.
    Better than 90% of all the "mini" starters on the aftermarket.
    Truckdoctor Andy likes this.
  7. squirrel
    14" flywheel on those trucks.
    The factory bolts for a 1999 454 have a metric shank, and a 3/8-16 thread, so they fit the modern metric starter properly to the block, which even in 99 used the old style threads.
  8. Clik
    Clik
    Thanks ya'll.
  9. stillrunners
    stillrunners
    from dallas
    How do they work on a Goodwrench stock 350 ?
  10. squirrel
    probably just fine.
    it's the same starter, look up some late 90s truck with a 350.
