Folks Of Interest BIG DADDY Don Garlits
Discussion in 'The Hokey Ass Message Board' started by fastcar1953, Jan 23, 2023.
  1. fastcar1953
    fastcar1953
  2. aircap
    aircap
    I refuse to turn off my ad-blocker, which is why I unsubscribed from Hemmings Daily.
    Bob Lowry and Ned Ludd like this.
  3. Beanscoot
    Beanscoot
    I have ad blocker, and the article was okay for me.
  4. Mike VV
    Mike VV
    from SoCal
    I found the part that actually DOES say, that he was NOT...the first to use a mid-mount (rear !) engine location.
    So it was good to see that mentioned. I didn't read the whole thing.
    Mike
  5. bobss396
    bobss396
    I read up on this many years ago, he came upon slowing the steering down and from there the car worked. Too many drivers were killed or maimed by blower explosions themselves with the FED design.
    belair likes this.
  6. 19Eddy30
    19Eddy30
    from VA
    You are correct , there was others before & where not known to be successful,
    Its been 35 40 years since hearing story from him, from what I recall ,he was still in hospital or right after wards thinking & discussing to get a RED to work with some one else & they though of & experimenting with slowing steering down
  7. theHIGHLANDER
    theHIGHLANDER
  8. dreracecar
    dreracecar
    from so-cal
    Before Garlits had his accident, and that was the "kickstart" for him to commit to building a RE car. Contrary to the Magazine--- Garlits did not have an epiphany- Magazine writers get paid by the word
    AND Garlits built his car with too fast of steering to start with, because he thought it was needed, Went back to conventional ratio like dragsters have been running for years, and that took care of it[​IMG]
    Deuces likes this.
  9. dreracecar
    dreracecar
    from so-cal
    Some were successful, but not a "NAME" driver to convince others to give up what they had and build new. Woody/Foster built one and crashed it, Foster told Don he thought the steering needed to be faster, to which Garlits did just that--- which was the wrong thing to do-- went back to normal ratio and it worked just fine
    FinnishFireball likes this.
  10. FinnishFireball
    FinnishFireball
    This is how Pat Foster tells the steering saga at wediditforlove pages:
    In his own words, here's how Patty answered the question: "How did the ill-fated Woody car come to be?"
    "There was no particular reason that Woody and I decided to build a back motored car. It began as lunch talk and grew from there. We decided to do the car with Woody supplying the materials and me donating the labor. We approached John Bateman to use his running gear and one of his 392's. He agreed, so the work began. We felt to be able to achieve the balance of the better running front motor cars of the era we needed to get the static load on the rear as high as possible so we inverted the rear end, used a small gear drive off the pinion to reverse the rotation, came back through the rear housing to the bell housing. Back of block to centerline of rear ended up about 18 ".
    Some how, John and Woody had a falling apart and Leland Kolb ended up the motor supplier. After two outings with the piece, both marred by poor handling, we slowed the steering from the regular 6-1 ratio to 10-1 and headed to the Beach for more testing. The car hooked hard and made a very nice, straight hard run until entering the lights, at which time it picked up the front end violently, got on the fifth wheel just behind the seat, tipped on to left rear and catapulted the car over the right lane guardrail where it struck a light pole. By the way, we started in the left lane.
    Garlits called me a week or so later in the hospital and asked my opinion was the accident, as he was thinking of building a similar car after his accident at Long Beach. I told him to put a wing on the front, no fifth wheel and to slow the steering, the rest is history."
    Pat Foster
    alanp561 and bobss396 like this.
  11. dreracecar
    dreracecar
    from so-cal
    Happened to be good friends with Hall of Fame ch***is builder Don Long--- who was right there during the change over--- Tells a different story and all his cars ran the conventual steering ratio. I think the biggest issue was that the driving style was so different between the two and that is where most of the problems were
  12. theHIGHLANDER
    theHIGHLANDER
    Big said the same thing, it wasn't just the steering, the drivers were reacting like they always had, but they were way up front vs all the way back.
