Event Coverage Big daddy goes racing with the 60 Elco!
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, May 27, 2023.
  1. Lloyd's paint & glass
    Shoot Jeff! For $45 we had a great time.
  2. saltflats
    saltflats
    from Missouri
    Support your local track.
  3. spanners
    spanners
    I didn't start drag racing till I was 54 and now at 66 I still wear the grin each time I do a run. I think I'm up to 660 runs since I started.
  4. s55mercury66
    s55mercury66
    from SW Wyoming
    Don't want to get too far astray here, but that brought back a flood of 1980s memories, #1, Chargin' Charlie, B4 Boggs, #71 Delmas Conley, and the the boys from a little further South, like Purvis and the guy with the B&D Boiler car, Smith? Oh well, get the 454 done, so you can break some stuff ;)
  5. Mr48chev
    Looks like a lot of fun. I raced back in the day when you ran in the cl*** your car got put in by weight and advertised hp and I ended up in G stock running a 14.25 bone stock car and at least once having t0 run against a 62 Chevy wagon with a 409 4 speed with a back window covered with national record holder stickers and NHRA cl*** win stickers. He ran 12.6 something.
    The local 1/4 mile track is 13.5 miles from the house and some times you can hear the big boys run from the house. the Little 1/8 mile track is 116 miles away but might be more fun for a low buck bracket racing rig.
  6. Lloyd's paint & glass
    I guess you heard that little Jack died? I also did a lot of paint work for Mike Francis, which was Steve's dad.
  7. Lloyd's paint & glass
    Every damn street car around here was running a canted valve engine out of somebody's late model at one point it seemed lmao! I graduated with little Jack, we'd hang around the race/ machine shop and get the cast off speed parts lol.
  8. guthriesmith
    guthriesmith
    I bet. We paid $40 just to watch. o_O I should have asked what it was to actually race. I could have seen what my O/T car would have done. :D
  9. 427 sleeper
    427 sleeper
    Put a 5 series gear in that Sum***** and see what happen's. :D
  10. Lloyd's paint & glass
    I think it was $35 to race plus $10 for crew member Ashley lol..
    catdad49, enloe, mad mikey and 2 others like this.
  11. Lloyd's paint & glass
    But then I'd be stuck looking at it sitting in the yard, I like driving it too much to ruin it :p I'll fix it with the big block torque :cool:
  12. Lloyd's paint & glass
    I'm gonna run with the straight axle group in Clay City on August 12th. Surely to hell I can have it sorted out by then lol. That's 1/4 mile.
  13. 427 sleeper
    427 sleeper
    Should'a put an Old's rear end in there... Easy gear swap's and period correct... LOL!!! NOW... who in the Hell can afford an Old's rear with multiple center sections??? Not Me, that's for Damn sure! :p
  14. Lloyd's paint & glass
    It's pretty obvious that I've gotta change the 10 bolt when I put the big block in lol. I'm already looking for a 9" Ford. Then I could have 2 center sections to swap out!
    High test 63, enloe and mad mikey like this.
  15. Lloyd's paint & glass
    Ashley was pissed that I didn't burn the tires in the water box, I said 2 reasons, I'm running street tires, and the damn thing won't burn the tires lmao!!
    High test 63, catdad49, enloe and 9 others like this.
  16. Lloyd's paint & glass
    275-60 street tires. I drove the car to the track, ran it through 3 times, and drove it back home lol. No worries on hooking up Billy, maybe on some oil, on a hill, with a line lock, and the front wheels chocked :rolleyes::D
    catdad49, enloe, mad mikey and 6 others like this.
  17. -Brent-
    -Brent-
    That will be way fun!
    Getting the 1/8th sorted will help a ton. I'm sure we could help you spend some money, too... hahaha.
  18. Los_Control
    Los_Control
    from TX
    I once had a 64 or 65 Elcamino? Honestly I never liked it, tried to sell it twice eventually took it to a car lot & traded it in on a jeep CJ5.
    That car had the best running 283/4spd I ever owned.
    It was a 2brl carb, no working choke .... turn the key & it would start instantly. A choke would only be in the way. Summer or winter, made no difference.
    To spin the tires was a joke, it would do it all day long.
    Possible a decent 2 barrel carb would improve your 60 ft time. Improving your total ET.
    Then build up from there to a 4 barrel?
    Or possibly your 4 barrel secondaries are kicking in too soon drowning you with excess fuel?
    Manual linkage or vacuum, that can be adjusted.
    enloe and Lloyd's paint & glass like this.
  19. Lloyd's paint & glass
    Yeah I'm going back to a heavy spring in the vacuum secondary tmrw ;)
    enloe, mad mikey and Truckdoctor Andy like this.
  20. Hard to comment, not knowing anything about the combination..Engine, trans , rear, weight?
    Always fun though...I can add that :)
    Lloyd's paint & glass likes this.
  21. Lloyd's paint & glass
    .030 283, power pack heads shaved .007, flat tops, 449 lift, 214 duration @ .050 dual plane with a 600 Holley, electronic aftermarket distributor with an external pertronix coil. Turbo 350, 10 bolt posi with 3.42 gears. 28" tall tires :D now you're up to speed.
    WC145, catdad49, -Brent- and 5 others like this.
  22. LOL Almost.
    Weight? Converter?
    Lloyd's paint & glass and enloe like this.
  23. squirrel
    Heavy. Stock.
    (probably 3800ish pounds with driver?)
  24. JimSibley
    JimSibley
    Bad***! The slowest car on the track is faster than the guy that didnt come and race!
    WC145, lewk, Tim and 15 others like this.
  25. wraymen
    wraymen
    Just found this, very cool! Nothing better than going down the track and driving it home with nothing broken. As far as the time slips, now I realize your comment back when I said my wagon wasn’t fast.
    I’m betting that you will see them improve every trip even before you put in the BB.
  26. Budget36
    Budget36
    I don’t know about the power pack heads (sue me) but seems after the surfacing you should have a decent CR. Cam seems good for a 283.
    Seems it would take a lot of grunt to spin 275/60’s with a 283 and a TH350 with a standard converter.
    Maybe you need a looser converter to get going better? That cam is larger than grocery getter 350’s, but should be enough to wake up a 283 I’d think? Could it be you’re launching to far below the power band?
    WC145 and SS327 like this.
  27. Lloyd's paint & glass
    Yep, stock converter, was supposed to be a 2400, but it's not. And I'm guess 3600lbs with me. I've gutted a lot. Not even a floor in the bed.
    WC145, 427 sleeper and SS327 like this.
  28. 57 Fargo
    57 Fargo
    maybe closer to 4000 with Lloyd…:)
    Sorry Lloyd!
    Davesblue50 and 427 sleeper like this.
  29. Lloyd's paint & glass
    Well ya gotta keep in mind, I didn't build a 283 with the intentions of going racing. I built this with the intentions of replacing the 350 in my wagon that lost oil pressure, but the guy that bought my 57 didn't want the 283, he was putting an LS in it. So the 283 went in the camino, now here we are. Yeah the "power pack" heads are a joke, probably meant something 60 years ago, but what I've been taught right here on the hamb is that a 283 has nothing going for it but compression and rpm. So you have to run the 58cc head with a flat top piston if you want any compression at all, then if you put a big whoop *** camshaft in it, the overlap will destroy your compression. Hence why in running the cam that i am, 114⁰ lobe separation. I'm not in the market to make a drag car, and absolutely not trying to make the 283 "hot", but I do want it to run right. I need all of the 200 horsepower to work in unison lmao! Some guy here dogged me about an electric fan, and when I said the mechanical fan was robbing me of horsepower he made fun of me, probably had a little **** and a fat ugly smelly wife, but that's beside the point lmao, but yes, when you make 200-250 horsepower, they all count!! There's no doubt in my mind that this car will turn a 9 in the 1/8th, just gotta figure out what's going on with it. But yes we're on the same page about power pack heads ;)
  30. Lloyd's paint & glass
    It's OK Lane, I didn't ask for this huge **** :D
